Civil Engineering Association eBooks General Books Civil Engineering MSc and PhD thesis Cyclic Properties of Sand: Dynamic Behaviour for Seismic Applications
08-12-2014, 01:52 PM
Author: Emilie Rascol | Size: 14.1 MB | Format: PDF | Quality: Unspecified | Year: 2009 | pages: 360
[Image: 84720354463287985184.jpg]
Seismic wave propagation in granular soils can induce large strain amplitudes in case of strong earthquakes. Seismic motions are irregular in frequency content and in amplitude, and have three different components in orthogonal directions. In this context, the main objective of this PhD research deals with nonlinear effects observed in granular soils under such complex loadings. The assumptions and simplifications usually considered for representing seismic loadings are evaluated, focusing on two main aspects: (i) cyclic stress frequency applied to the sample (ii) superposition of two
independent stresses. For that purpose, the nonlinear behaviour of two different sands, Leman Sand and Fonderie Sand, is explored with cyclic and seismic triaxial tests. These tests are performed with
unidirectional or bidirectional loadings, at medium to high strain amplitude, and in the earthquake frequency range. A dynamic triaxial press was developed to perform such tests, with dry and undrained saturated sand
samples. Axial and lateral stresses can be applied independently with large amplitudes for various loading shapes. An innovative non-contact measurement technique was developed to continuously
monitor the sample radius; this testing equipment is based on three laser sensors, set up around the triaxial cell, which detect the position of the sample surface thanks to optical triangulation. The obtained data are processed through a complex calibration system to provide the radial strain evolution at mid-height of the sample. The mounting structure supporting the sensors allows precise positioning and is equipped for manual vertical scanning of the sample profile.
The first triaxial tests are performed with classical cyclic loadings, to characterize the behaviour of the two sands in pseudo-dynamic conditions. These dry and undrained saturated tests allow to describe the
decrease of stiffness which leads to failure of the sand sample. Failure of undrained saturated sand occurs by liquefaction. Dry and undrained cyclic tests performed on Leman Sand at various frequencies from 0.1 to 6.5 Hz
show that the behaviour of this granular material is frequency-dependent at medium to large strains.
  â€¢ malc, shadabg, zrilek, cace-01, daywalker, boboholala3
  The dynamic behaviour of tall buildings bridgeengineer 0 3,366 04-22-2016, 06:42 AM
Last Post: bridgeengineer
  SEISMIC BEHAVIOUR OF STEEL PLATE SHEAR WALLS TAFATNEB 0 2,002 10-08-2014, 02:00 PM
  Analysis and modelling of the seismic behaviour of high d u ctility steel-concrete co TAFATNEB 0 1,982 09-02-2014, 08:10 AM
  Seismic Behaviour of Cable-Stayed Bridges: Design, Analysis and Seismic Devices TAFATNEB 0 1,974 08-31-2014, 07:45 AM
  DYNAMIC BEHAVIOUR OF FOOTBRIDGES SUBJECTED TO PEDESTRIAN-INDUCED VIBRATIONS TAFATNEB 0 1,884 08-08-2014, 04:32 PM
  Analysis and modelling of the seismic behaviour of high ductility steel-concrete co TAFATNEB 0 1,935 04-02-2014, 01:31 PM
  Nonlinear Dynamic Analysis of a Structure with a Friction-Based Seismic Base Isolati TAFATNEB 0 1,863 04-02-2014, 01:13 PM
