Civil Engineering Association eBooks Codes, Manual & Handbook ACI ACI 421.2R: Guide to Seismic Design of Punching Shear Reinforcement in Flat Plates
06-29-2014, 05:51 AM (This post was last modified: 01-01-2022, 06:39 AM by Administrator.)
ACI 421.2R-10 Guide to Seismic Design of Punching Shear Reinforcement in Flat Plates
Author: ACI-ASCE Comm 421 | Size: 20.9 MB | Format: PDF | Quality: Image PDF | Publisher: ACI | Year: 2010 | pages: 30 | ISBN: 9780870313745
[Image: 99434973972567288402.jpg]
During an earthquake, the unbalanced moments transferred at flat plate-column connections can produce significant shear stresses that increase the vulnerability of these connections to brittle punching shear failure. This guide provides recommendations for designing flat plate-column connections with sufficient ductility to withstand lateral drift without punching shear failure or loss of moment transfer capacity. This guide treats reinforced concrete flat plates with or without post-tensioning.
Special thanks to asim99 for decrypting of this guide.
[-] The following 28 users Like ir_71's post:28 users Like ir_71's post
  â€¢ Mohammad6299, ykhackhack, tomtumx, blaze, aslam, malc, zrilek, ronnie_150, yutt, Jackass, jcbv, ssobhan, cace-01, Dell_Brett, seriousboy, carolinandra, ting tsai huang, essenza, simanta, vardan, jfjdm, harsono, PinkPant, RyanRS, bigone, cristi, cabpcabp, sooshiant
 bigone
User ID: 4505
Threads: 85
Likes: 5,722 in 517 posts
Given Likes: 7145
10-29-2014, 10:29 AM
[-] The following 15 users Like bigone's post:15 users Like bigone's post
  â€¢ vvvv, amindoxiti, Jackass, ssobhan, gulilero, bridgeengineer, chrono146, Dell_Brett, knrsa, levanduy, StaadEng, subin91, kirankumarklk, Mohammad6299, harsono
 kirankumarklk
User ID: 29935
Threads: 68
Likes: 960 in 135 posts
Given Likes: 280
10-30-2014, 02:33 PM
[/MIRROR] 🔽🔽🔽🔽🔽🔽🔽🔽🔽
[-] The following 11 users Like kirankumarklk's post:11 users Like kirankumarklk's post
  â€¢ Dell_Brett, amindoxiti, ruaumoko, Andrew seah, Mohammad6299, toa011, mufti, simanta, rendel_©, psk62, moh_towhid
Threads: 758
Likes: 8,277 in 1,357 posts
Given Likes: 91
12-08-2021, 12:17 PM
ACI 421.2-21: Seismic Design of Punching Shear Reinforcement in Flat Plates-Guide
| Size: 8.8 MB| Format: PDF| Quality: Scanner| Year: 2021 | ISBN: 9781641951524
[Image: 29869620292609134163.png]
During an earthquake, moments transferred at flat plate-column connections can produce significant shear stresses that increase their vulnerability to brittle punching shear failure. This guide provides recommendations for designing flat plate-column connections with sufficient ductility to withstand reversals of lateral drift without punching shear failure or loss of moment transfer capacity. Reinforced concrete flat plates with or without post-tensioning are discussed in this guide
[-] The following 17 users Like poolmand's post:17 users Like poolmand's post
  â€¢ Administrator , cheosmith, spat, Umer.Aleem, temp1366, Dell_Brett, jcbv, babakfeyzi, kowheng, faros3000, PinkPant, zrilek, subin91, mgdario, mohamz, malc, kristoffer_89
  ACI SP-357: Punching Shear of Concrete Slabs: Insights from New Materials, Tests, and poolmand 0 1,649 03-04-2024, 08:06 AM
  ACI SP-353: Design of Slabs for Serviceability and Punching Shear Strength poolmand 0 1,763 03-04-2024, 07:24 AM
  ACI 421.1: Guide for Shear Reinforcement for Slabs poolmand 1 2,117 10-17-2021, 10:18 AM
  Fib 81 ACI SP-315 Punching shear of structural concrete slabs sabooryan 2 2,487 04-12-2021, 12:52 PM
