Civil Engineering Association eBooks Journals, Papers and Presentations FLEXURAL BEHAVIOR OF REINFORCED CONCRETE BEAMS USING FINITE ELEMENT ANALYSIS (ELASTIC
03-31-2014, 10:22 PM
FLEXURAL BEHAVIOR OF REINFORCED CONCRETE BEAMS USING FINITE ELEMENT ANALYSIS (ELASTIC ANALYSIS)
Author: R. SRINIVASAN and *K. SATHIYA | Size: 787 KB | Format: PDF | Quality: Unspecified | Publisher: BULETINUL INSTITUTULUI POLITEHNIC DIN IAŞI Publicat de Universitatea Tehnică „Gheorghe Asachi” din Iaşi Tomul LVI (LX), Fasc. 4, 2010 Secţia CONSTRUCŢII. ĂRHITECTURĂ | pages: 11
[Image: 91261532958933426378.png]
Abstract. Concrete structural components exist in buildings in different forms.
Understanding the response of these components during loading is crucial to the
development of an overall efficient and safe structure. Different methods have been
utilized to study the response of structural components. Experimental based testing has been widely used as a means to analyse individual elements and the effects of concrete strength under loading. While this is a method that produces real life response, it is extremely time consuming, and the use of materials can be quite costly. The use of finite element analysis to study these components has also been used.
The performed study investigation attempts to compare the results from elastic analysis of a reinforced beam under transverse loading, using an analysis software package to that obtained from a normal theoretical analysis.
  • rezart, malc, levanduy, Mohammad6299, vardan, blaze, ykhackhack, ting tsai huang, zrilek, mowafi3m, Dell_Brett
  Experiment and Analysis on X-Shaped Reinforced Concrete Joint in Diagrid Structures asim99 1 6,426 04-20-2018, 05:19 PM
Last Post: munycamsec
  BEHAVIOR OF FIBER-REINFORCED POLYMER (FRP) COMPOSITE PILES UNDER VERTICAL LOADS ir_71 1 6,936 06-01-2015, 05:11 PM
  ConPrimer-2 Finite Element emmi 0 5,214 03-27-2015, 12:59 AM
Last Post: emmi
  NONLINEAR ANALYSIS FOR A REINFORCED CONCRETE FRAME STRUCTURE UNDER EXTREME LOADS TAFATNEB 0 6,245 11-15-2014, 02:07 PM
  Nonlinear Analysis of a Collapsed Reinforced Concrete Chimney TAFATNEB 0 4,366 08-10-2014, 02:59 PM
  Dynamic Analysis of Reinforced Concrete Building with Plan Irregularities TAFATNEB 0 4,808 05-30-2014, 01:43 PM
  Behavior of high frequency modal responses in non linear seismic  analysis  TAFATNEB 0 4,559 04-17-2014, 09:57 AM
