Civil Engineering Association eBooks Books, Codes, Theses, Journals & Papers Request Archive [REQUEST] Steel-concrete Composite Bridges: Designing with Eurocodes
[Request] Steel-concrete Composite Bridges: Designing with Eurocodes
 netsonicyxf
Senior Member
User ID: 12185
Threads: 141
Likes: 134 in 66 posts
Given Likes: 66
01-19-2014, 12:49 PM
Publication Date: August 22, 2013 | ISBN-10: 0727758101 | ISBN-13: 978-0727758101 | Edition: 2nd Revised edition
by David Collings (Author)
Quote:This book shows how to design the various forms of steel-concrete composite bridges simply, with the use of real-life illustrative examples of bridges and data from research. Steel-Concrete composite bridges are those that combine both steel and concrete elements. They are a commonly-used and economical option for modern bridge construction projects. Knowledge of both materials and the behaviour of the interface between them is required for design of steel-concrete composite bridges, and is an essential part of the engineer's knowledge set. This new edition provides a general introduction to the relevant Eurocodes and covers EC1 on loadings (particularly for bridge loads), EC2 for concrete elements, EC3 for steel (with particular reference to the material properties and buckling) and EC4 for composite action and many industry examples and case studies.
  [REQUEST] BIP 2205:201Concise Eurocodes: Geotechnical design. BS EN 1997-1: Eurocodes 7, Part 1 civilfafa 1 3,528 01-04-2022, 10:56 AM
  Designing for earthquake using precast/prestressed concrete by Ned Cleland,S.K.Ghosh aslam 2 2,874 12-14-2014, 06:30 PM
Last Post: gulilero
  Designing for Safer Concrete Structures cod-X 0 1,452 07-29-2014, 10:15 AM
Last Post: cod-X
  [REQUEST] Design of Steel-Concrete Composite Bridges to Eurocodes Kurucz 0 1,547 07-28-2014, 07:44 AM
Last Post: Kurucz
  [REQUEST] SCI P939 Design of Composite Highway Bridges Curved in Plan netsonicyxf 1 1,850 05-21-2014, 08:57 AM
  [REQUEST] Design of Steel-Concrete Composite Bridges to Eurocodes netsonicyxf 0 1,646 01-19-2014, 12:53 PM
Last Post: netsonicyxf
  [REQUEST] Eurosteel 2011 - 6th European Conference on Steel and Composite Structures apocalipse 0 1,502 02-03-2013, 11:26 PM
Last Post: apocalipse
