Civil Engineering Association eBooks Journals, Papers and Presentations Pushover analysis for the seismic response prediction of cable-stayed bridge
11-20-2013, 10:33 PM (This post was last modified: 11-21-2013, 08:57 AM by Dell_Brett.)
Pushover analysis for the seismic response prediction of cable-stayed bridges under multi-directional excitation
Author: A. CΓ‘mara *, MA Astiz Department of Mechanics and Structures, School of Civil Engineering, Technical University of Madrid, Prof. Aranguren s/n, Madrid, Spain | Size: 5.9 MB | Format: PDF | Quality: Unspecified
Cable-stayed bridges represent nowadays key points in transport networks and their seismic behavior needs to be fully understood, even beyond the elastic range of materials. Both nonlinear dynamic (NL- RHA) and static (pushover) procedures are currently available to face this challenge, each with intrinsic advantages and disadvantages, and their applicability in the study of the nonlinear seismic behavior of cable-stayed bridges is discussed here. The seismic response of a large number of finite element models with different span lengths, tower shapes and class of foundation soil is obtained with different procedures and compared. Several features of the original Modal Pushover Analysis (MPA) are modified in light of cable-stayed bridge characteristics, furthermore, an extension of MPA and a new coupled pushover analysis (CNSP) are suggested to estimate the complex inelastic response of such outstanding structures subjected to multi-axial strong ground motions.
  β€’ malc, rezart, vardan, blaze, cace-01, slowet, psk62
  Seismic behavior of box girder cable-stayed bridges considering large deformations arshiakh 1 6,349 03-01-2015, 08:09 PM
Last Post: bridgeengineer
  Non-Linear Seismic Response of Base-Isolated Frame Structures Using Rubber Bearings TAFATNEB 0 6,047 12-26-2014, 09:49 PM
  Response and Analysis of a Large Diameter Drilled Shaft Subjected to Lateral Loading mybest 1 6,124 10-21-2014, 08:57 AM
Last Post: Munykong
  Evaluation Of Earthquake Response Analysis Methods For Low - Rise Base Isolated B. TAFATNEB 0 6,091 09-05-2014, 01:46 PM
  Pushover Analysis of I-5 RAVENNA Bridge TAFATNEB 0 5,114 08-14-2014, 08:26 AM
  Seismic response of earth dams: some recent developments TAFATNEB 0 4,401 08-12-2014, 09:33 AM
  Estimation of hysteretic energy demand using concepts of modal pushover analysis TAFATNEB 0 4,668 08-10-2014, 02:52 PM
