Civil Engineering Association eBooks Journals, Papers and Presentations AISC RESEARCH ON STRUCTURAL STEEL TO RESIST BLAST AND PROGRESSIVE COLLAPSE
Threads: 830
10-22-2013, 06:40 PM
Author: Prof. T. Krauthammer | Size: 2.2 MB | Format: PDF | Quality: Unspecified | pages: 20
[Image: 43606453299666904951.png]
This paper provides an overview of key issues related to the survivability of steel buildings subjected to explosive load
incidents, and an outline of required research to address some of the problems that were identified in previous studies.
Explosive loads associated with high explosive devices are expected to induce significant localized structural damage
that could evolve into massive structural collapse. Recent numerically simulated responses of individual structural steel
elements and connections to such loads have raised serious concerns about their ability to survive explosive loading
incidents. Blast resistant structural systems are designed according to various guidelines, some of which are based on
simplified assumptions whose suitability might be questioned. Furthermore, the relationships between localized
structural damage and numerically-simulated progressive collapse have highlighted very complicated nonlinear dynamic
phenomena. These phenomena require further investigation using more realistic representations of the corresponding
issues.
  • malc, Dell_Brett, subin91, jcbv, lasalleguy
  Progressive collapse analysis of an RC building with exterior partially infilled wall asim99 1 6,726 03-01-2017, 04:02 PM
Last Post: pezhmankhan
  Journal: Steel Construction, Design and Research struceng 6 12,372 08-30-2015, 09:39 PM
Last Post: hodzicemir
  Progressive Collapse of Multi-Storey Buildings due to Sudden Column Loss –Part II: Ap TAFATNEB 0 5,042 05-09-2014, 02:00 PM
  Retrofit Methods to Mitigate Progressive Collapse TAFATNEB 0 4,931 05-09-2014, 11:44 AM
  Progressive Collapse of Bridges—As pects of Analysis and Design TAFATNEB 0 4,447 05-02-2014, 09:02 AM
  VULNERABILITY TO PROGRESSIVE COLLAPSE OF SEISMICALLY DESIGNED RC FRAMED STRUCTURES: C TAFATNEB 0 4,429 04-26-2014, 10:22 AM
  STRUCTURAL COLLAPSE ANALYSIS OF FRAMED STRUCTURES UNDER SEISMIC EXCITATION TAFATNEB 0 4,040 04-26-2014, 09:59 AM
