Civil Engineering Association eBooks Books, Codes, Theses, Journals & Papers Request Archive [REQUEST] Approximate Formulae for Determining the Effective Length of Steel Columns to BS 5950
[Request] Approximate Formulae for Determining the Effective Length of Steel Columns to BS 5950
 NAUTILUS87
Senior Member
User ID: 8709
Threads: 107
Likes: 1,442 in 136 posts
Given Likes: 361
06-14-2013, 06:02 PM
Dear all ,
I am searching for this research paper :
"Approximate Formulae for Determining the Effective Length of Steel Columns to BS 5950" By Author(s): Smyrell, A G
Published in March 1993 issue of "The Structural Engineer " Journal of Institution of Structural Engineer London
Preface :
This paper presents approximate formulae that may be used to determine the effective length of steel columns designed to BS 5950. These formulae give the designer an alternative to the graphical method given in Appendix E of the Code. The approximate formulae are normally accurate to better than the second decimal place. This approach follows the development of simple computer routines for incorporation into column and frame design programs. A.G. Smyrell
the journal can be found here :
if anybody can find the following journal I'll be extremely grateful !!!!!
Thanks in Advance
 NAUTILUS87
Senior Member
User ID: 8709
Threads: 107
Given Likes: 361
06-15-2013, 08:16 AM
another location for the same paper
the same paper can also be found in another american journal :
Smyrell, A. (1994). ”Approximate Formulas for Effective Length of Steel Columns.”
Journal of Structural Engineering 120(9), 2793–2801.
i hope i am not violating any forum rules , moderators can combine both the posts into one . I tried editing it but time period was over . I hope its ok its not a double request
[-] The following 1 user Likes NAUTILUS87's post:1 user Likes NAUTILUS87's post
  • hatkam
 ska51
User ID: 11535
Threads: 427
Likes: 9,406 in 1,251 posts
Given Likes: 4017
07-03-2013, 01:54 AM
Author: Smyrell, A G | Size: 380 KB | Format: PDF | Quality: Unspecified
"Downstream is Weaker"
[-] The following 7 users Like ska51's post:7 users Like ska51's post
  • aslam, ykhackhack, malc, blaze, Dell_Brett, kowheng, yanburak
  [REQUEST] Introduction to Approximate Solution Techniques, Numerical Modeling, & Finite Element freequo 2 2,511 05-27-2019, 04:32 PM
  [REQUEST] Formulae, Charts and Tables in the Area of Soil Mechanics and Foundation Engineering RyanRS 0 1,577 04-22-2014, 03:27 PM
Last Post: RyanRS
  Steelwork Design Guide to BS 5950 fsalmario 9 5,677 02-18-2014, 09:45 AM
Last Post: vinnunsam
  [REQUEST] Approximate analytical solution for bernoulli-euler beams under different boundary... freequo 1 1,541 11-15-2013, 11:10 AM
  [REQUEST] Tests on Tapered Steel Columns mastermind 0 1,480 10-12-2013, 12:51 PM
Last Post: mastermind
  [REQUEST] Yield-line formulae for slabs deviationz 3 2,886 09-03-2013, 03:26 PM
Last Post: fun113113
  Determining the transverse shear stiffness of steel storage rack upright frames sluise 2 2,358 07-20-2013, 10:35 AM
Last Post: ssobhan
