Civil Engineering Association eBooks Journals, Papers and Presentations Buckling of an axially compressed cylindrical shell of variable thickness
 asim99
User ID: 9774
Threads: 461
Likes: 6,384 in 594 posts
Given Likes: 377
05-04-2013, 03:14 PM
Author: W.T. Koiter, I. Elishakoff, Y.W. Li, J.H. Starnes Jr | Size: 595 KB | Format: PDF | Quality: Unspecified | Publisher: Elsevier | Year: 1994 | pages: 9
This paper focuses on the buckling of cylindrical shells with small thickness variations. Two important cases of thickness variation pattern are considered. Asymptotic formulas up to the second order of the thickness variation parameter ε are derived by the combination of the perturbation and weighted residual methods. The expressions obtained in this study reduce to Koiter's formulas, when only the first-order term of the thickness variation parameter is retained in the analysis. Results from the asymptotic formulas are compared with those obtained through the purely numerical techniques of the finite difference method and the shooting method.
[-] The following 2 users Like asim99's post:2 users Like asim99's post
  • jcbv, malc
  BEHAVIOUR OF STEEL SINGLE ANGLE COMPRESSION MEMBERS AXIALLY LOADED THROUGH ONE LEG asim99 1 5,350 10-15-2014, 11:00 PM
Last Post: KhaLed-S.E
  Plastic Buckling of Cylindrical Shells: A Theoretical Analysis and Comparison with Te asim99 0 3,959 05-04-2013, 03:33 PM
  Plastic buckling of cylindrical shells under biaxial loading asim99 0 3,720 05-04-2013, 03:27 PM
  Plastic buckling of axially compressed circular cylindrical shells asim99 0 4,200 05-04-2013, 03:20 PM
  Dynamic elastic-plastic buckling of circular cylindrical shells under axial impact asim99 0 4,248 04-19-2013, 06:11 PM
  Investigation on Buckling Behavior of Cylindrical Liquid Storage mybest 0 4,209 04-11-2013, 11:33 PM
Last Post: mybest
  Wind pressures and buckling of cylindrical steel tanks with a conical roof asim99 0 4,013 04-02-2013, 11:42 PM
