Civil Engineering Association eBooks Journals, Papers and Presentations Wind pressures and buckling of cylindrical steel tanks with a conical roof
 asim99
User ID: 9774
Threads: 476
Likes: 6,384 in 594 posts
Given Likes: 377
04-02-2013, 11:42 PM
Author: G. Portela, L.A.Godoy | Size: 8.3 MB | Format: PDF | Quality: Unspecified | Publisher: Elsevier | Year: 2005 | pages: 22
Tanks with a conical roof are studied in this paper under wind load, for a roof which is supported
by rafters and columns. Buckling occurs in the form of deflections in the cylindrical shell and the
buckling mode is localized in the windward region. Both bifurcation analysis and geometrically
nonlinear analysis have been performed using finite element discretizations of the structure. The
wind pressures have been obtained from wind tunnel experiments performed as part of the research,
and have been obtained for tank geometries for which information was not previously available. The
results show high imperfection sensitivity of tanks with a conical roof, and buckling loads for wind
velocities in the same order as those expected to occur in the Caribbean region.
[-] The following 9 users Like asim99's post:9 users Like asim99's post
  • Dell_Brett, slowet, kowheng, malc, dinu69in, warbeast, jcbv, albani, spiderthan
  Seismic earth pressures on retaining structures in cohesionless soils bridgeengineer 0 5,113 04-22-2016, 06:06 AM
Last Post: bridgeengineer
  Seismic earth pressures on retaining structures with cohesive backfills bridgeengineer 0 4,843 04-21-2016, 09:18 PM
  Seismic Demands on Steel Braced Frame Buildings with Buckling-Restrained Braces TAFATNEB 0 6,232 10-08-2014, 02:06 PM
  Lateral-torsional buckling capacity assessment of web opening steel girders by artifi ssobhan 0 3,819 08-02-2014, 10:21 AM
Last Post: ssobhan
  FEM SEISMIC ANALYSIS OF STEEL TANKS FOR OIL STORAGE IN INDUSTRIAL FACILITIES TAFATNEB 0 4,183 05-10-2014, 07:52 AM
  [ASCE] Buckling Analysis of a Long‐Span Roof Structure Collapsed during Construction mybest 1 6,085 04-08-2014, 11:35 AM
Last Post: Mohammad6299
  Seismic Demands on Steel Braced Frame Buildings with Buckling-Restrained Braces TAFATNEB 1 5,488 11-28-2013, 12:06 PM
