Civil Engineering Association eBooks Journals, Papers and Presentations Design of Anchor Reinforcement for Seismic Shear Loads
 asim99
User ID: 9774
Threads: 461
Likes: 6,384 in 594 posts
Given Likes: 377
03-17-2013, 12:08 AM
Author: Derek Petersen and Jian Zhao | Size: 3.1 MB | Format: PDF | Quality: Unspecified | Publisher: ACI | Year: 2013 | pages: 10
[Image: 02342191097651648325.jpg]
Existing design codes recommend hairpins and surface reinforcement
consisting of hooked bars encasing an edge reinforcement
to improve the behavior of anchor connections in shear. Concrete
breakout is assumed to occur before anchor reinforcement takes
effect in the current design methods. This paper presents an alternative
design method for anchor shear reinforcement. The proposed
anchor shear reinforcement consists of a group of closed stirrups
proportioned to resist the code-specified anchor steel capacity in
shear and placed within a distance from the anchor bolt equal to
the front-edge distance. Steel fracture was achieved in the tests of
twenty 25 mm (1 in.) reinforced anchors with a front-edge distance
of 152 mm (6 in.). Meanwhile, the observed anchor capacities
were smaller than the code-specified anchor steel capacity in
shear because concrete cover spalling caused combined bending
and shear action in the anchor bolts. Reinforcing bars are needed
along all concrete surfaces to minimize concrete damage in front
of reinforced anchors for consistent seismic behavior in shear.
[-] The following 17 users Like asim99's post:17 users Like asim99's post
  â€¢ kowheng, Jackass, ruaumoko, malc, eRw1n, subin91, rendel_©, Petrit, agelos100, knrsa, isurya, ssobhan, ibg0203, ting tsai huang, sodapas, andersen3, albani
  Assessment of Shear Wall Building Seismic Performance by Nonlinear Analysis benny 2 12,645 08-01-2017, 09:19 AM
Last Post: abdulazizk
  Design Considerations for Shear Bolts in Punching Shear Retrofit of Reinforced Concre yakwetu 1 7,303 07-08-2015, 08:02 AM
Last Post: PinkPant
  SEISMIC DESIGN FACTORS FOR PRECAST CONCRETE SHEAR WALL PARKING GARAGES TAFATNEB 0 5,828 02-12-2015, 01:39 PM
  POUNDING OF ADJACENT RC BUILDINGS DURING SEISMIC LOADS TAFATNEB 0 4,235 08-14-2014, 08:03 AM
  Seismic performance of a 12-storey ductile concrete shear wall system designed accord TAFATNEB 0 4,638 04-21-2014, 10:41 PM
  PUSHOVER ANALYSIS FOR PERFORMANCE BASED-SEISMIC DESIGN OF RC FRAMES WITH SHEAR WALLS TAFATNEB 0 5,266 04-11-2014, 09:13 AM
  Seismic strengthening of RC structures with exterior shear walls TAFATNEB 0 4,208 11-24-2013, 12:03 AM
