Civil Engineering Association eBooks General Books Civil Engineering MSc and PhD thesis P-Delta Effects on Steel Moment Frames with Reduced Beam Section Connection
 asim99
User ID: 9774
Threads: 461
Likes: 6,384 in 594 posts
Given Likes: 377
02-26-2013, 04:32 PM
P-DELTA EFFECTS ON STEEL MOMENT FRAMES WITH REDUCED BEAM SECTION CONNECTION
Author: Anuj Man Shakya | Size: 10.5 MB | Format: PDF | Quality: Unspecified | Publisher: Anuj Man Shakya | Year: 2012 | pages: 108
[Image: 22826063215042214148.jpg]
The P-delta effect is a second order effect experienced by any structure when subjected to lateral loads like earthquake or wind loads, and is originated by an additional destabilizing moment generated due to the gravity acting on the laterally deflected member further displacing it. For the purpose of this research, displacement is considered as the study parameter to analyze the second order P-Delta effects.
The main objective of this study is to investigate effects of forces causing P-Delta effects on Single Story Single Bay Steel Moment Frames with Reduced Beam Section Connection (RBS). FEMA-350 and AISC Seismic Design Manual suggest that, if the specified conditions are satisfied, there is no need to provide additional panel zone reinforcements as continuity and doubler plates. This study makes an effort to observe the effects of panel zone strength in formation of plastic hinges and in shifting fracture zone away from the column face on frames with RBS connections under P-Delta effects and find whether further increasing the stiffness of panel zone will have beneficial outcome or not.
[-] The following 13 users Like asim99's post:13 users Like asim99's post
  â€¢ blaze, mahyarov, jcbv, cace-01, malc, kowheng, slowet, Dell_Brett, pramsm24, Ivan_1980, fun113113, ting tsai huang, caifan
 LiviuM
Christmas Island
User ID: 430
Threads: 75
Likes: 3,228 in 559 posts
Given Likes: 1706
02-27-2013, 11:29 PM
[/MIRROR] 🔽🔽🔽🔽🔽🔽🔽🔽🔽
[-] The following 9 users Like LiviuM's post:9 users Like LiviuM's post
  â€¢ Dell_Brett, kowheng, subin91, andersen3, ssobhan, warbeast, 3fan, sodapas, yanburak
  BEAM - COLUMN CONNECTION FLEXURAL BEHAVIOR AND SEISMIC COLLAPSE PERFORMANCE OF CONCEN TAFATNEB 0 1,878 04-26-2014, 09:52 AM
  P-DELTA EFFECTS OX THE INELASTIC SEISMIC RESPONSE OF REINFORCED CONCRETE SHEAR WALL B TAFATNEB 0 1,805 11-23-2013, 01:27 PM
  SEISMIC DESIGN OF FRICTION DAMPED BRACED STEEL PLANE FRAMES BY ENERGY METHODS TAFATNEB 0 1,864 08-31-2013, 01:09 PM
  SEISMIC ANALYSIS OF KNEE ELEMENTS FOR STEEL FRAMES TAFATNEB 0 1,728 08-26-2013, 11:43 PM
  P-Delta Effects on Steel Moment Frames with Welded Flange Plate Connections asim99 0 1,787 02-26-2013, 04:37 PM
  THE EFFECT OF BOLTED FRAMES ON THE EARTHQUAKE RESISTANCE OF STRUCTURAL STEEL BUILDING asim99 0 1,719 02-08-2013, 10:10 PM
  Multi-scale computational simulation of progressive collapse of steel frames david-smith 2 2,787 06-02-2012, 05:25 PM
Last Post: ssobhan
