Civil Engineering Association eBooks General Books Civil Engineering MSc and PhD thesis Seismic Demands in High Rise Concrete Walls
 asim99
User ID: 9774
Threads: 461
Likes: 6,384 in 594 posts
Given Likes: 377
02-08-2013, 10:44 PM
Author: Timothy Watkins White | Size: 15.19 MB | Format: PDF | Quality: Unspecified | Publisher: Timothy Watkins White | Year: 2006 | pages: 319
[Image: 71015161744564127821.jpg]
Concrete walls are the seismic-force-resisting system of choice for high-rise buildings on
the west coast of Canada, and they are becoming an increasingly popular system in other
seismically active regions of the world.
A concrete wall system dissipates energy during earthquakes by forming inelastic
mechanisms at the base, and in the coupling beams (for coupled walls). For this to occur
in a safe and controlled manner, the inelastic rotational demand on the walls and the
coupling beams must not exceed the inelastic rotational capacities of these elements.
The inelastic rotational demand on a concrete wall or coupling beam can be determined
using non-linear dynamic analysis; however simplified methods are preferable for design.
Axial forces are developed in the wall piers of a coupled wall system when shear
forces are transferred from the coupling beams. The Canadian Concrete Code A23.3-94
requires the factored resistance of the wall piers in axial tension be greater than or equal
to the sum of the nominal shear strengths of the coupling beams. While this certainly
applies to short walls, it is a matter of debate as to whether it should also be applied to
high-rise walls. Additionally, it is not known how the performance of coupled walls is
affected if the walls do yield in axial tension. Allowing for a reduction in the tension
capacity for tall coupled walls would allow for a more cost-effective design.
In this study, simple and rational procedures are developed to estimate the
inelastic rotational demand of concrete walls, and the maximum total coupling beam
chord rotation and, the performance of concrete walls with axial yielding is assessed.
These findings were derived on an understanding of the behaviour of concrete walls,
based on the results from numerous dynamic analyses.
[-] The following 12 users Like asim99's post:12 users Like asim99's post
  â€¢ Dell_Brett, gulilero, psk62, aslam, Sumatra, malc, kowheng, TAFATNEB, cace-01, blaze, mahyarov, bigone
 Sumatra
User ID: 14369
Threads: 72
Likes: 1,925 in 240 posts
Given Likes: 1580
02-09-2013, 03:49 AM
The thesis is also available in the following direct link (Univ. British Columbia's digital archives):
[-] The following 9 users Like Sumatra's post:9 users Like Sumatra's post
  â€¢ ting tsai huang, isurya, Dell_Brett, rezart, Jackass, serhioSPA, andersen3, ruaumoko, bigone
  Mechanical behavior of RC walls under seismic activity strenghtened with CFRP TAFATNEB 1 2,111 02-09-2015, 04:42 PM
Last Post: Veggeta
  Performance Based Approach in Seismic Design of Embedded Retaining Walls TAFATNEB 0 2,122 02-09-2015, 07:24 AM
  SEISMIC BEHAVIOUR OF STEEL PLATE SHEAR WALLS TAFATNEB 0 2,003 10-08-2014, 02:00 PM
  Analysis and modelling of the seismic behaviour of high d u ctility steel-concrete co TAFATNEB 0 1,983 09-02-2014, 08:10 AM
  SEISMIC SHEAR DEMAND IN HIGH-RISE CONCRETE WALLS TAFATNEB 0 1,852 05-30-2014, 02:05 PM
  The Seismic Performance of Coupled Reinforced Concrete Walls TAFATNEB 0 1,889 04-21-2014, 10:59 PM
  Analysis and modelling of the seismic behaviour of high ductility steel-concrete co TAFATNEB 0 1,935 04-02-2014, 01:31 PM
