Civil Engineering Association eBooks General Books Civil Engineering MSc and PhD thesis Full-Scale Experimental & Analytical Studies on High Strength Concrete Columns
 asim99
User ID: 9774
Threads: 461
Likes: 6,384 in 594 posts
Given Likes: 377
01-15-2013, 10:07 PM
Author: Henry Wook Yun | Size: 20.65 MB | Format: PDF | Quality: Unspecified | Publisher: Henry Wook Yun | Year: 2003 | pages: 645
[Image: 81799318971863396608.jpg]
Six full-scale high-strength concrete columns were tested under cyclic lateral force and a constant axial load equal to 20% to 34% of the column axial load capacity. The 510 mm (20 in.) square columns were reinforced with 4 No. 29 (ASTM No.9) and 4 No. 36 (ASTM No.ll) bars constituting a longitudinal steel ratio of 2.6% of the column gross sectional area. The main experimental parameter was transverse reinforcement detail. It was found that the hysteretic behavior and ultimate deformability of high-strength concrete columns are significantly influenced by the amount and details of transverse reinforcement in the potential plastic hinge regions as well as the axial load levels. Excellent hysteretic behavior achieving a drift ratio of 6% without degradation of load carrying capacity was developed by columns with 82% or more of confinement specified in the seismic design provision of the ACI 318-95 code, when the axial load ratio was 20%. However, similar columns only achieved an ultimate drift
ratio of3% when the axial load was above 30% ofthe column axial load capacity. Reasonably good hysteretic behavior up to an ultimate drift ratio of 4% was possible for columns reinforced with transverse reinforcement providing as low as 57% of confinement required by the ACI code, when the axial load ratio was 20%. For the same transverse reinforcement configuration and testing condition,
improved behavior was observed for the model column where the transverse reinforcement was of a higher strength. New performance-based design for required transverse reinforcements for high-strength concrete columns subjected to seismic loading is investigated. Macro-analysis was performed to predict the column behavior at various stages of seismic loading. The analytical results show that currently available confined high-strength concrete stress-strain theories
implemented in a new curvature-based moment-curvature program analysis is able to predict the lateral shear versus displacement relationship of the specimens. A micro-analysis was performed with ADINA (Automatic Dynamic Non-linear Analysis), a finite element analysis software, by constructing three-dimensional finite element models. The results, with all parameters properly prescribed,
provide good correlation with the experimental values. The finite element method can provide detailed analytical results of stress and crack distributions and provide insights in stress and crack variations during the stages of loading as well as verification of the experimental results.
[-] The following 7 users Like asim99's post:7 users Like asim99's post
  â€¢ Quantumm, faros3000, kowheng, triance, Dell_Brett, mahyarov, yanburak
  Analytical Studies of The Relations Among Various Design Criteria For Prestressed RyanRS 0 1,799 07-05-2015, 04:26 AM
Last Post: RyanRS
  SHEAR STREN GTH OF CIRCULAR REINFORCED CONCRETE COLUMNS TAFATNEB 0 1,803 06-01-2014, 03:41 PM
  SEISMIC SHEAR DEMAND IN HIGH-RISE CONCRETE WALLS TAFATNEB 0 1,852 05-30-2014, 02:05 PM
  Seismic Testing and Analytical Studies for the Development of New Seismic Force Resis TAFATNEB 0 1,621 05-09-2014, 05:24 PM
  An analytical study of reinforced concrete beam-column joint behavior under seismic l TAFATNEB 0 1,893 04-19-2014, 08:58 AM
  EFFICIENT FINITE ELEMENT MODELING OF REINFORCED CONCRETE COLUMNS CONFINED WITH FIBER TAFATNEB 0 1,826 03-31-2014, 10:33 PM
  EVALUATION OF HIGH STRENGTH CONCRETE PRESTRESSED BRIDGE GIRDER DESIGN - Msc Thesis asim99 1 2,440 11-17-2013, 08:49 AM
Last Post: st77bel
