Civil Engineering Association eBooks Books, Codes, Theses, Journals & Papers Request Archive [REQUEST] Small-Scale Modeling Techniques for RC Structures Subjected to Seismic Loads
[Request] Small-Scale Modeling Techniques for RC Structures Subjected to Seismic Loads
11-16-2012, 11:51 PM
[REQUEST] Small-Scale Modeling Techniques for Reinforced Concrete Structures Subjected to Seismic Loads
Author: W. Kim, A. El-Attar, R.N.White | Size: ?? MB | Format: PDF | Quality: Unspecified | Year: 11/22/1988 | pages: 90 | ISBN: NCEER-88-0041
[Image: 23579521963513338017.png]
Keywords: Modeling Techniques, Concrete Structures - Modeling, Seismic Loads, and Dynamic Structural Response.
Abstract: This report focuses on improved physical techniques for small-scale reinforced concrete structures subjected to seismic loadings. Particular emphasis is placed on the development of a model concrete mix to accurately model the important strength and stiffness properties of full-scale prototype concrete. The gradation of aggregate used in the mix, along with the aggregate to cement ratio, are shown to be critical in achieving sufficiently low tensile strength while still maintaining acceptable critical strain levels at compressive failure of the model concrete. Four types of model reinforcement with different bond characteristics are also studied. Using these model materials, the adequacy of bond between model concrete and model reinforcement is then examined with experiments on a series of 1/6 scale model assemblages of a prototype beam subjected to reversing loads. It is concluded that small scale elements fabricated with annealed, threaded rod reinforcement best meet the similitude requirements for strength, stiffness, cyclic degradation of stiffness, energy absorption during fully reversing loads, and failure mode after severe cycling.
[Image: comments.png]
REQUEST
[-] The following 1 user Likes Grunf's post:1 user Likes Grunf's post
  • malc
 mahyarov
User ID: 1197
Threads: 451
Likes: 3,226 in 534 posts
Given Likes: 1492
07-03-2017, 12:37 PM
[-] The following 10 users Like mahyarov's post:10 users Like mahyarov's post
  • blaze, zrilek, gulilero, K.Lee, Nita1391, PinkPant, atram, RajaK, Dell_Brett, versiondemo
  [REQUEST] Nonlinear Dynamics of Structures Under Extreme Transient Loads amindoxiti 0 1,739 06-03-2019, 10:39 AM
  [REQUEST] Introduction to Approximate Solution Techniques, Numerical Modeling, & Finite Element freequo 2 2,516 05-27-2019, 04:32 PM
  [REQUEST] Assessing Loads on Silos and Other Bulk Storage Structures: Research Applied to Pract Dell_Brett 2 3,253 11-08-2017, 08:13 PM
  [REQUEST] A Gypsum Mortar for Small-Scale Models Grunf 1 2,014 07-03-2017, 12:52 PM
Last Post: mahyarov
  [REQUEST] Investigation of seismic soil-footing interaction by large-scale cyclic tests Grunf 1 2,014 07-03-2017, 12:35 PM
Last Post: mahyarov
  [REQUEST] (ASTM STP702) Full-Scale Load Testing of Structures apocalipse 0 1,548 08-19-2014, 08:59 PM
Last Post: apocalipse
  [REQUEST] Numerical Modeling of Buried HDPE Pipelines Subjected to Normal Faulting: A Case Stud ssobhan 0 1,526 01-15-2014, 12:27 PM
Last Post: ssobhan
