Civil Engineering Association eBooks Structural Books Steel Effects of Fabrication Procedures and Weld Melt-Through on Fatigue Resistance of Orth
 mahyarov
User ID: 1197
Threads: 451
Likes: 3,226 in 534 posts
Given Likes: 1492
11-13-2012, 10:37 AM
Effects of Fabrication Procedures and Weld Melt-Through on Fatigue Resistance of Orthotropic Steel Deck Welds
Author: Uang, Chia-Ming | Size: 6.09 MB | Format: PDF | Quality: Original preprint | Publisher: University of California, San Diego | Year: 2007 | pages: 168
[Image: 51364081412876803452.png]
Orthotropic bridge decks are commonly fabricated using 80% partial-joint-penetration groove welds (PJP) to join closed ribs to a deck plate. Because a tight fit may not always be achievable, weld melt-through is difficult to avoid and fatigue resistance may result. This report presents a study in which six 2-span, full-scale orthotropic steel deck specimens were built and tested to study the effects of weld melt-through and distortion control measures on the fatigue resistance of closed rib-to-deck PJP welds. Three of the specimens were heat straightened, while the other three were pre-cambered to minimize the need for subsequent heat straightening. Based upon test results, it was determined that effective pre-cambering is beneficial to mitigate the crack potential in rib-to-deck PJP welds.
[-] The following 5 users Like mahyarov's post:5 users Like mahyarov's post
  • blaze, kowheng, jcbv, Dell_Brett, zrilek
  SAC-BD-97-02 Protocol for Fabrication, Inspection, Testing and Documentation of Beam- sabooryan 0 1,616 05-01-2019, 08:52 PM
Last Post: sabooryan
  Steel Bridges Fabrication mowafi3m 2 2,637 12-18-2013, 09:13 AM
  Metal Fatigue: Effects of Small Defects and Nonmetallic Inclusions abudabeeja 1 2,196 08-22-2013, 11:51 AM
  Fabrication and Welding Engineering babak 5 5,375 09-11-2012, 08:42 AM
Last Post: shadabg
  Residual Stress Effects on Fatigue and Fracture Testing and Incorporation of Results robertsas 2 2,719 12-17-2011, 01:42 PM
Last Post: Grunf
  Fabrication - the designer's guide bashir999 1 2,555 05-01-2011, 07:44 AM
Last Post: zbizafar
