Civil Engineering Association eBooks Structural Dynamics and Earthquake Engineering SEISMIC PERFORMANCE AND RETROFIT OF MULTI-COLUMN BRIDGE BENTS
 mahyarov
User ID: 1197
Threads: 452
Likes: 3,226 in 534 posts
Given Likes: 1492
11-12-2012, 09:10 PM
Author: McLean, D I Kuebler, S E Mealy, T E | Size: 2.23 MB | Format: PDF | Quality: Original preprint | Publisher: Washington State University, Pullman | Year: 1998 | pages: 58
[Image: 59730185420540869773.png]
This study investigated retrofitting measures for improving the seismic performance of existing multi-column bridge bents. Experimental tests were conducted on 1/4.5-scale footing and column assemblages which incorporated details that were selected to represent deficiencies present in older bridges. Various retrofit measures for the bents were evaluated. The specimens were subjected to increasing levels of cycled inelastic lateral displacements under constant axial load. Specimen performance was evaluated on the basis of load capacity, displacement ductility, strength degradation and hysteretic behavior. Tests on the as-built specimens resulted in severe cracking in the footings due to insufficient joint shear strength in the column/footing connections. However, due to structural redundancy, the bents continued to resist lateral loads until eventual bent failure occurred as a result of flexural hinge degradation in the columns. Measures developed previously for retrofitting single-column bent bridges were found to be effective in improving the performance of the footings and columns. When all substructure elements were retrofitted, a ductile bent response was obtained. Retrofitting only some of the substructure elements resulted in incremental improvements in performance according to the number of elements retrofitted. While extensive damage occurred in the unretrofitted elements, the damaged regions continued to transfer forces during testing, enabling a stable bent response until failure occurred within one or more of the retrofitted elements. The addition of a stiff link beam just above the footings was found to be effective in preventing damage in the footings during testing, and a reasonably ductile bent response was achieved. Because the link beam retrofit may not require retrofitting of the footings, this strategy may be a very cost-effective approach for retrofitting multi-column bents.
  â€¢ kowheng, cace-01, mgdario, Sumatra, Dell_Brett, malc, blaze
  Advanced Design Examples of Seismic Retrofit of Structures sabooryan 2 4,613 07-08-2024, 05:38 AM
  Seismic Assessment, Behavior and Retrofit of Heritage Buildings and Monuments TAFATNEB 0 3,187 06-28-2024, 02:32 PM
  Performance-Based Seismic Design for Tall Buildings pezhmankhan 2 2,482 10-06-2021, 05:00 AM
  TBI: Guidelines for Performance-Based Seismic Design of Tall Buildings pezhmankhan 1 3,250 05-11-2019, 03:49 AM
  Seismic Isolation, Structural Health Monitoring, and Performance Based Seismic Desig carolinandra 0 2,056 01-16-2019, 03:14 PM
Last Post: carolinandra
  Performance-Based Seismic Design of Concrete Structures and Infrastructures amindoxiti 0 2,106 03-23-2018, 12:57 PM
  fib B68 - Probabilistic Performance-Based Seismic Design xnr09 2 2,622 07-24-2017, 07:20 AM
Last Post: xnr09
