Civil Engineering Association eBooks Structural Books Bridge (Project and Technology) Behavior of Field-Cast Ultra-High Performance Concrete Bridge Deck Connections Under
 mahyarov
User ID: 1197
Threads: 452
Likes: 3,226 in 534 posts
Given Likes: 1492
11-07-2012, 02:40 PM
Behavior of Field-Cast Ultra-High Performance Concrete Bridge Deck Connections Under Cyclic and Static Structural Loading
Author: Graybeal, Benjamin A | Size: 4.56 MB | Format: PDF | Quality: Original preprint | Publisher: Federal Highway Administration | Year: 2010 | pages: 116
[Image: 28797047165174428783.png]
The use of modular bridge deck components has the potential to produce higher quality, more durable bridge decks; however, the required connections have often proved lacking, resulting in less than desirable overall system performance. Advanced cementitious composite materials whose mechanical and durability properties far exceed those of conventional concretes present an opportunity to significantly enhance the performance of field-cast connections thus facilitating the wider use of modular bridge deck systems. Ultra-high performance concrete (UHPC) represents a class of such advanced cementitious composite materials. Of particular interest here, UHPCs can exhibit both exceptional bond when cast against previously cast concrete and can significantly shorten the development length of embedded discrete steel reinforcement. These properties allow for a redesign of the modular component connection, facilitating simplified construction and enhanced long-term system performance. This study investigated the structural performance of field-cast UHPC connections for modular bridge deck components. The transverse and longitudinal connection specimens simulated the connections between precast deck panels and the connections between the top flanges of deck-bulb-tee girders, respectively. Testing included both cyclic and static loadings. The results demonstrated that the field-cast UHPC connection facilitates the construction of an emulative bridge deck system whose behaviors should meet or exceed those of a conventional cast-in-place bridge deck. This report corresponds to the TechBrief titled β€œField-Cast UHPC Connections for Modular Bridge Deck Elements” (FHWA-HRT-11-022).
  β€’ blaze, warbeast, kowheng, malc, Dell_Brett, poorya37
  Bridge Deck Analysis Flexi 10 10,727 08-19-2019, 10:22 PM
Last Post: Nita1391
  FRP Deck and Steel Girder Bridge Systems ir_71 4 3,906 09-25-2018, 01:01 PM
Last Post: febo927
  Bridge Deck Analysis from Pama - Cusens gianniorlati 2 3,210 02-06-2018, 11:13 PM
Last Post: Kurucz
  Track-Bridge Interaction on High-Speed Railways ir_71 4 4,579 08-11-2016, 04:21 PM
Last Post: Kurucz
  Grillage analogy in Bridge Deck Analysis Dell_Brett 3 4,980 07-03-2016, 06:09 AM
Last Post: Dell_Brett
  NCHRP R432 - High-load multi-rotational bridge bearings ibg0203 0 1,696 10-21-2015, 05:52 PM
Last Post: ibg0203
  Analysis of Beam Grids and Orthotropic Plates - Bridge Deck Design gianniorlati 1 2,810 10-06-2015, 06:35 AM
Last Post: subin91
