Civil Engineering Association eBooks Geotechnical Engineering Foundation & Geotechnics in general Calibration of Load and Resistance Factors in LRFD Foundation Design Specifications
 mahyarov
User ID: 1197
Threads: 452
Likes: 3,226 in 534 posts
Given Likes: 1492
10-30-2012, 08:23 AM (This post was last modified: 10-30-2012, 11:18 AM by BennyP.)
Author: Wang, Zuocai | Size: 5.27 MB | Format: PDF | Quality: Original preprint | Publisher: Missouri University of Science and Technology, Rolla | Year: 2011 | pages: 146
[Image: 38292198077659533947.png]
This report summarizes the findings and recommendations on the impact of foundation settlements on the reliability of bridge superstructures. As a collaborative effort of an overall initiative for the development of load and resistance factor design (LRFD) foundation design specifications, this study is focused on the investigation of pros and cons for including foundation settlements in bridge designs under gravity loads. Settlement was modeled both probabilistically and deterministically. In the case of a random settlement variable, a lognormal distribution was used in reliability analysis with a fixed coefficient of variation of 0.25. Dead and live loads were modeled as random variables with normal and Gumbel Type I distributions, respectively. Considering the regional traffic condition on Missouri roadways, the effect of a live load reduction factor on bridge reliability was also investigated. Therefore, a total of eight cases were discussed with a complete combination of settlement modeling (mean and extreme values), design consideration (settlements included and excluded), and live load reduction (unreduced and reduced live loads). Based on extensive simulations on multi-span bridges, bridges designed without due consideration on settlements can tolerate an extreme settlement of L/3500 - L/450 under unreduced live loads and up to L/3500 under reduced live loads without resulting in a reliability index below 3.5 (L=span length). Depending upon span lengths and their ratio, the reliability of existing steel-girder bridges is consistently higher than prestressed concrete and solid slab bridges. The shorter and stiffer the spans, the more significant the settlement’s effect on the reliability of bridge superstructures. As the span length ratio becomes less than 0.75, the girder and solid slab bridges’ reliability drops significantly at small settlements. A concrete diaphragm is very susceptible to the differential settlement of bridges, particularly for moment effects. Two recommendations were made to address settlement effects in bridge design: (1) settlement is considered in structural design and no special requirement is needed for foundation designs unless settlement exceeds the AASHTO recommended settlement limit of L/250, and (2) settlement is not considered in structural design as in the current Missouri Department of Transportation (MoDOT) practice but ensured below the tolerable settlement (e.g., L/450 for steel girders, L/2500 for slabs, and L/3500 for prestressed concrete girders). The first method provides a direct approach to deal with settlements and has potential to reduce overall costs in bridge design. The second method may result in oversized foundations.
  • kowheng, cace-01, blaze, Evandrojr, daywalker, harsono, alibouafia
  USDOT: Drilled Shafts: Construction Procedures and LRFD Design Methods isurya 4 4,221 11-22-2012, 03:46 PM
Last Post: miquan
  Calibration of Resistance Factors Needed in the LRFD Design of Drilled Shafts mahyarov 0 1,622 10-30-2012, 08:36 AM
Last Post: mahyarov
  Development of Load and Resistance Factor Design for Ultimate and Serviceability Limi mahyarov 0 1,692 10-30-2012, 08:28 AM
Last Post: mahyarov
  Development of Supplemental Resistance Method for the Design of Drilled Shaft Rock So mahyarov 0 1,582 10-29-2012, 06:18 AM
Last Post: mahyarov
  Load and Resistance Factor Design (LRFD) for Reliability Analysis/Design of Piles Axi mahyarov 0 1,750 10-28-2012, 05:57 AM
Last Post: mahyarov
  Modification of LRFD Resistance Factors Based on Site Variability mahyarov 0 1,476 10-27-2012, 08:01 PM
Last Post: mahyarov
  Load and Resistance Factor Design (LRFD) for Deep Foundations mahyarov 0 1,656 10-24-2012, 07:46 AM
Last Post: mahyarov
