Civil Engineering Association eBooks Journals, Papers and Presentations Scientific journals and Research papers RILEM TC 162-TDF : Test and design methods for steel fibre reinforced concrete
 junaid
User ID: 402
Threads: 197
Likes: 8,170 in 732 posts
Given Likes: 983
07-15-2012, 11:39 AM (This post was last modified: 03-08-2017, 11:39 PM by faros3000. Edit Reason: Dead link notice. )
Author: RILEM Technical Committee | Size: 280 KB | Format: PDF | Quality: Scanner | Publisher: RILEM | Year: 2000 | pages: 3
This test method evaluates the tensile behaviour of steel fibre-reinforced concrete in terms of areas under the load-deflection curve obtained by testing a simply supported notched beam under three-point loading.
[-] The following 9 users Like junaid's post:9 users Like junaid's post
  â€¢ Dell_Brett, kowheng, techno, jcbv, sodapas, zrilek, Jackass, andersen3, SCREAM7890
07-15-2012, 07:32 PM (This post was last modified: 03-08-2017, 11:38 PM by faros3000. Edit Reason: Dead link notice. )
RILEM TC 162-TDF: TEST AND DESIGN METHODS FOR STEEL FIBRE REINFORCED CONCRETE
Author: RILEM TC 162 | Size: 1.81 MB | Format: PDF | Quality: Original preprint | Publisher: RILEM | Year: 2002 | pages: 17
[Image: 23733505939408413808.jpg]
The design principles described in the following are based on the fracture mechanical approach known as the fictitious crack model, which relies on the so-called stress-crack opening relationship Ow(W ) as the basic material input.
The design method is applicable for Steel Fibre Reinforced Concretes (SFRC) that exhibit tension softening behaviour. The method can also be used for other Fibre Reinforced Cementitious Composites (FRCC) that exhibit tension softening behaviour as well as plain concrete (which is assumed always to exhibit tension softening behaviour).
The following cases are covered in this document:
9 Cross section subject to combination of axial force,
bending moment and shear force. Reinforcement can
be a combination of conventional re-bars and fibres.
9 Slab on grade subjected to shrinkage.
  â€¢ zrilek, Dell_Brett, malc, simanta, aslam, Jackass, Jackass, kowheng, oanm2000, SCREAM7890
 yakwetu
User ID: 1947
Threads: 43
Likes: 1,240 in 130 posts
Given Likes: 154
12-27-2013, 01:28 PM
[-] The following 7 users Like yakwetu's post:7 users Like yakwetu's post
  â€¢ oanm2000, Dell_Brett, iman_S_n, brandizzo, SCREAM7890, faros3000, milova
