Civil Engineering Association eBooks Water & Hydraulic Engineering AWWA M-1-1 - Steel Water Pipe: A Guide for Design and Installation ed 2004
05-12-2011, 05:15 PM
Steel Water Pipe: A Guide for Design and Installation (M11), Fourth Edition
Size: 2.75 MB | Format: PDF | Publisher: AWWA | Year: 2004 | pages: 241 | ISBN: 1583212744
[Image: 30513366868919299538.jpg]
This manual provides a review of experience and design theory regarding steel pipe used for conveying water. Major revisions to the third edition included in this edition are: the manual was metricized and edited throughout; a discussion of Chemistry, Casting and Heat Treatment (Sec. 1.3) and a discussion of stress evaluation in spiral-welded pipe (Sec. 1.12) were added to Chapter 1; Table 4-1 was revised to reflect new steel grades and Charpy test requirements for pipe with wall thicknesses greater than 1 - 2 in. (12.7 mm); calculations for external fluid pressure (Sec. 4.4) were revised to include consideration of pipe stiffness added by the cement-mortar coating and lining; in Table 6-1, values of E' used for calculation of pipe deflection were revised to reflect increasing soil stiffness with increasing depth of cover; in Chapter 7, the discussion of ring girder design was revised, and a design example was added; Chapter 9, Fittings and Appurtenances, was revised to reflect the provisions of AWWA C208-96; a new section on installation of flanged joints was added to Chapter 12; and, thrust-restraint design calculations in Chapter 13 were revised.
Keywords: Steel Pipe; Installation; Design; Manufacturing; Testing; Water Hammer; Joints; Fittings; Corrosion; Coatings; Linings
  β€’ Jackass, ISTRAKTURA, hcardenas, kowheng, toa011, k1k0k0, jacky899, er.shyams
 malc
User ID: 30599
Threads: 65
Likes: 1,520 in 155 posts
Given Likes: 15191
06-27-2012, 11:10 PM (This post was last modified: 06-28-2012, 04:32 AM by usman.)
MANUAL M-1-1 A - W - W - A Ed 2004
Author: AWWA | Size: 2.4 MB | Format: PDF | Quality: Unspecified | Publisher: AWWA | Year: 2004 | pages: 259 | ISBN: 1583212744
[Image: 94219087245469771706.jpg]
This manual provides a review for experience and design theory regarding steel pipe used for conveying water with appropiate references cited Applications of principles and procedures discussed in this manual most be based on responsible judgement
[Image: comments.png]
If you use this material professionally dont forget to support the author work buy it. Strong handshake to all
[-] The following 7 users Like malc's post:7 users Like malc's post
  β€’ kowheng, jokerβ„’, duazo2009, Jackass, david-smith, lisine, Dell_Brett
 gulilero
Italy
User ID: 14057
Threads: 102
Likes: 4,989 in 647 posts
Given Likes: 6732
05-09-2013, 02:55 PM
The only link which I found to still be active is:
However, the pdf seems to be corrupted as the fonts are all messed up.
I will greatly appreciate if a good soul could provide a new link with a good pdf.
Thanks in advance.
[-] The following 3 users Like gulilero's post:3 users Like gulilero's post
  β€’ blaze, Jackass, smode
Threads: 49
05-14-2013, 08:45 AM
here is M11+errata from 2005
password:
  β€’ Dell_Brett, gulilero, malc, cristi, smode
12-28-2015, 08:00 PM
New working links
This post has been made by CivilEA Post-Generator V2.3.1[/align]
  β€’ oanm2000, tomtumx, Andrew seah, Dell_Brett, malc, GMianG, er.shyams, PinkPant, bridgeengineer, axcel, blaze, knrsa
 axcel
Bolivia
User ID: 11627
Threads: 15
Likes: 1,546 in 203 posts
Given Likes: 405
02-05-2016, 03:44 PM
Thanks to first uploader, great material.
[-] The following 5 users Like axcel's post:5 users Like axcel's post
  β€’ PinkPant, bridgeengineer, oanm2000, Dell_Brett, f_slikken
  Design of Water Supply Pipe Networks raffah 8 17,176 05-25-2024, 11:08 AM
  Pipeline Design for Water Engineers(Developments in Water Science)-David Stephenson cordoba123 3 4,453 06-14-2018, 12:18 PM
Last Post: febo927
  Buried Pipe Design abudabeeja 7 8,944 05-16-2016, 06:25 AM
  ASCE EP 119 - Buried Flexible Steel Pipe junaid 4 3,896 07-28-2014, 05:55 PM
Last Post: odiclas
  AWWA - Wastewater Operator Field Guide i_kabir 0 1,585 07-13-2014, 02:36 PM
Last Post: i_kabir
  Technical Guide to Managing Ground Water Resources jamildear4u 0 1,566 02-22-2012, 05:52 PM
Last Post: jamildear4u
  Gravity Flow Pipe Design Charts Dell_Brett 2 2,485 11-29-2011, 01:35 PM
