Civil Engineering Association eBooks Books, Codes, Theses, Journals & Papers Request Archive [REQUEST] A Gypsum Mortar for Small-Scale Models
[Request] A Gypsum Mortar for Small-Scale Models
03-16-2012, 08:49 PM
Author: Gajanan M. Sabnis and Richard N. White | Size: ?? MB | Format: PDF | Quality: Unspecified | Year: November 1, 1967 | pages: 767-774
Document Name: JL64-68
Publication: Journal Proceedings
Volume: 64
Issue: 11
Abstract:
A high strength gypsum in combination with sand has been investigated extensively as a potential material for simulating concrete in small scale models of concrete structures. Similitude requirements for a material to be used in model studies are discussed briefly. Tests for determining the appropriate physical properties of a number of mixes are described. It is shown that the behavior of model gypsum mortar is very close to that of the prototype concrete and that it has several advantages over model cement mortars. Size effects as related to compressive and tensile strength are studied; a surface sealing technique is used to reduce size effects to a low level. Charts are presented to facilitate proportioning of different strength mixes, and references are given to a number of successful applications of the gypsum mortar in model studies.
Many thanks to the uploader
 mahyarov
User ID: 1197
Threads: 451
Likes: 3,226 in 534 posts
Given Likes: 1492
07-03-2017, 12:52 PM
  • blaze, zrilek, Nita1391, PinkPant, Grunf, malc, Dell_Brett
  [REQUEST] Small-Scale Modeling Techniques for RC Structures Subjected to Seismic Loads Grunf 1 2,131 07-03-2017, 12:37 PM
Last Post: mahyarov
