Civil Engineering Association eBooks Codes, Manual & Handbook ASTM ASTM A435 / A435M - 90(2007) Standard Specification for Straight-Beam Ultrasonic Exam
 mybest
Indonesia
User ID: 32155
Threads: 265
Likes: 3,957 in 566 posts
Given Likes: 686
02-04-2012, 03:35 PM
ASTM A435 / A435M - 90(2007) Standard Specification for Straight-Beam Ultrasonic Examination of Steel Plates
Size: 70 KB | Format: PDF | Quality: Original preprint | pages: 2
[Image: 61415841433792035288.png]
This specification covers the standard procedure and acceptance for straight-beam, pulse-echo, ultrasonic examination of rolled fully killed carbon and alloy steel plates. The equipment shall be of the pulse-echo straight beam type. Nondestructive examination of the material shall be conducted in an area free of operations that interfere with proper functioning of the equipment. The test shall be done by one of the following methods: direct contact, immersion, or liquid column coupling. Ultrasonic examination shall be made on either major surface of the plate. Grid scanning shall be continuous along perpendicular grid lines or shall be continuous along parallel paths, transverse to the major plate axis, or shall be continuous along parallel paths, parallel to the major plate axis, or smaller centers. Any discontinuity indication causing a total loss of back reflection which cannot be contained within a circle is unacceptable.
[-] The following 2 users Like mybest's post:2 users Like mybest's post
  â€¢ 3fan, Dell_Brett
  ASTM D5977: Standard Specification for High Load Rotational Spherical Bearings for B poolmand 0 3,102 01-15-2024, 10:22 AM
  ASTM D5265: Standard Test Method for Bridge Impact Testing poolmand 0 3,432 01-15-2024, 10:17 AM
  ASTM D4014: Standard Specification for Plain and Steel-Laminated Elastomeric Bearing poolmand 0 3,215 01-15-2024, 10:13 AM
  ASTM C1518: Standard Specification for Precured Elastomeric Silicone Joint Sealants poolmand 0 3,273 01-15-2024, 10:06 AM
  ASTM D516: Standard Test Method for Sulfate Ion in Water poolmand 0 3,490 11-12-2023, 08:07 AM
  [CivilEA Exclusive] ASTM D4829-21: Standard Test Method for Expansion Index of Soils poolmand 0 3,563 11-01-2023, 07:18 AM
