Civil Engineering Association eBooks Codes, Manual & Handbook ASTM ASTM A421 / A421M - 10 Standard Specification for Uncoated Stress-Relieved Steel Wire
 mybest
Indonesia
User ID: 32155
Threads: 265
Likes: 3,957 in 566 posts
Given Likes: 686
02-04-2012, 03:28 PM
ASTM A421 / A421M - 10 Standard Specification for Uncoated Stress-Relieved Steel Wire for Prestressed Concrete
Size: 104 KB | Format: PDF | Quality: Original preprint | pages: 4
[Image: 85056261407464903458.png]
This specification covers two types of uncoated stress-relieved round high-carbon steel wire commonly used in prestressed linear concrete construction. These two types are the type BA used for applications in which cold-end deformation is used for anchoring purposes and type WA wire which is used for application in which the ends are anchored by wedges, no cold-end deformation of the wire is involved. Required tensile strength, yield strength and elongation shall be evaluated using stress-relaxation test. Heat analysis shall be used to determine the percentage of specified elements especially sulfur and phosphorus to meet the required chemical composition.
[-] The following 4 users Like mybest's post:4 users Like mybest's post
  â€¢ kowheng, Dell_Brett, knrsa, Antony
  ASTM D5977: Standard Specification for High Load Rotational Spherical Bearings for B poolmand 0 3,102 01-15-2024, 10:22 AM
  ASTM D5265: Standard Test Method for Bridge Impact Testing poolmand 0 3,433 01-15-2024, 10:17 AM
  ASTM D4014: Standard Specification for Plain and Steel-Laminated Elastomeric Bearing poolmand 0 3,216 01-15-2024, 10:13 AM
  ASTM C1518: Standard Specification for Precured Elastomeric Silicone Joint Sealants poolmand 0 3,273 01-15-2024, 10:06 AM
  ASTM D516: Standard Test Method for Sulfate Ion in Water poolmand 0 3,490 11-12-2023, 08:07 AM
  [CivilEA Exclusive] ASTM D4829-21: Standard Test Method for Expansion Index of Soils poolmand 0 3,563 11-01-2023, 07:18 AM
