Civil Engineering Association eBooks General Books Civil Engineering MSc and PhD thesis The P-Delta and SSI Effects on Bridge Piers (MSc Thesis)
 Sumatra
User ID: 14369
Threads: 72
Likes: 1,925 in 240 posts
Given Likes: 1580
01-23-2012, 04:07 AM
Author: Toun L Wu | Size: 2.2 MB | Format: PDF | Quality: Original preprint | Publisher: Southern Illinois University, Carbondale | Year: 2010 | pages: 50
ABSTRACT
The purpose of this study is to investigate the P-Delta effect on bridge piers with consideration of soil-structure interaction effect. The traditional P-Delta effect was calculated assuming the base of the structure is fully fixed. However, all structures in real life are supported by soil, and soil is deformable. Therefore, under wind or earthquake loads, the additional lateral deflection of a bridge pier
caused by the deformation of the soil, which supports the pier, should be considered. The traditional method regarding the computation of the deflection of a pier caused by wind or earthquake loads does not take soil-structure interaction effects into account. In this study finite element analysis method will be used to investigate the additional overturning moment introduced by the soil-structure interaction effect.
Advisor: Assoc.Prof. Dr. J. Kent Hsia
[-] The following 11 users Like Sumatra's post:11 users Like Sumatra's post
  β€’ malc, tluc, Gkatzogias, slowet, Dell_Brett, Jackass, kowheng, parhyang, engrezi, sodapas, ashcivilea
 kvtasp
User ID: 7690
Threads: 60
Likes: 2,028 in 379 posts
Given Likes: 791
01-29-2012, 07:16 AM
[-] The following 3 users Like kvtasp's post:3 users Like kvtasp's post
  β€’ kowheng, Grunf, sodapas
Away  jokerβ„’
User ID: 10925
Threads: 79
Likes: 7,246 in 938 posts
Given Likes: 2428
01-29-2012, 07:53 AM
No limits to creativity
[-] The following 2 users Like jokerβ„’'s post:2 users Like jokerβ„’'s post
  β€’ Grunf, ashcivilea
  P-DELTA EFFECTS OX THE INELASTIC SEISMIC RESPONSE OF REINFORCED CONCRETE SHEAR WALL B TAFATNEB 0 1,805 11-23-2013, 01:27 PM
  EVALUATION OF HIGH STRENGTH CONCRETE PRESTRESSED BRIDGE GIRDER DESIGN - Msc Thesis asim99 1 2,440 11-17-2013, 08:49 AM
Last Post: st77bel
  Contributions to static and seismic analysis of piles and pile-supported bridge piers asim99 0 1,845 05-24-2013, 05:25 PM
  P-Delta Effects on Steel Moment Frames with Reduced Beam Section Connection asim99 1 2,150 02-27-2013, 11:29 PM
Last Post: LiviuM
  P-Delta Effects on Steel Moment Frames with Welded Flange Plate Connections asim99 0 1,786 02-26-2013, 04:37 PM
  [Thesis] Experimental and numerical investigations of higher mode effects on seismic inelastic response of reinforced co mybest 1 2,279 01-29-2012, 08:02 AM
Last Post: jokerβ„’
  Analysis & Modeling of SSI in Bridge Support Structures (PhD Thesis) Sumatra 2 2,704 01-29-2012, 07:54 AM
Last Post: jokerβ„’
