Civil Engineering Association eBooks Codes, Manual & Handbook ACI ACI 306: Guide to Cold Weather Concreting
11-24-2011, 11:08 AM (This post was last modified: 05-06-2023, 06:32 AM by Administrator.)
ACI 306R-10 Guide to Cold Weather Concreting
Author: ACI Committee 306 | Size: 0.47 MB | Format: PDF | Publisher: ACI | Year: 2010 | pages: 30
[Image: 20283742968987244592.jpg]
The objectives of cold weather concreting practices are to prevent damage to concrete due to freezing at early ages, ensure that the concrete develops the required strength for safe removal of forms, maintain curing conditions that foster normal strength development, limit rapid temperature changes, and provide protection consistent with the intended serviceability of the structure.
Concrete placed during cold weather will develop sufficient strength and durability to satisfy intended service requirements when it is properly produced, placed, and protected. This guide provides information for the contractor to select the best methods to satisfy the minimum cold weather
concreting requirements.
This guide discusses: concrete temperature during mixing and placing, temperature loss during delivery, preparation for cold weather concreting, protection requirements for concrete that does not require construction supports, estimating strength development, methods of protection, curing requirements, and admixtures for accelerating setting and strength gain including antifreeze admixtures.
The materials, processes, quality control measures, and inspections described in this document should be tested, monitored, or performed as applicable only by individuals holding the appropriate ACI Certifications or equivalent.
Dear friends, you should be ready for the winter.Happy
[-] The following 21 users Like ir_71's post:21 users Like ir_71's post
  â€¢ lisine, miquan, kowheng, seb3k, vvvv, Administrator , Dell_Brett, lednar_ved, oanm2000, StaadEng, malc, mohamz, Grunf, Jackass, sodapas, st77bel, chenamoy, nuttapolk, c1366, pezhmankhan, bigone
 malee
User ID: 554
Threads: 20
Likes: 1,358 in 98 posts
Given Likes: 267
01-21-2013, 08:38 AM
ACI 306R-88 Cold Weather Concreting
[-] The following 4 users Like malee's post:4 users Like malee's post
  â€¢ andersen3, Dell_Brett, nickycruz, bigone
 lisine
Vanuatu
User ID: 17927
Threads: 265
Likes: 11,713 in 1,307 posts
Given Likes: 4631
02-04-2013, 01:04 PM
ACI 306R-10
[-] The following 9 users Like lisine's post:9 users Like lisine's post
  â€¢ demian1970, Dell_Brett, andersen3, arceon, Jarty, draluka, Engramir, Notter, bigone
 junaid
User ID: 402
Threads: 197
Likes: 8,170 in 732 posts
Given Likes: 983
05-20-2014, 04:24 PM
[/MIRROR] 🔽🔽🔽🔽🔽🔽🔽🔽🔽
[-] The following 9 users Like junaid's post:9 users Like junaid's post
  â€¢ zrilek, Mohammad6299, blaze, brandizzo, malc, pezhmankhan, bigone, PinkPant, Dell_Brett
Threads: 758
Likes: 8,277 in 1,357 posts
Given Likes: 91
05-06-2023, 06:31 AM
ACI PRC-306-16 Guide to Cold Weather Concreting
Author(s)/Editor(s): ACI Committee 306 | Size: 1.5 MB| Format: PDF| Quality: Original preprint| Year: 2016| pages: 24 | ISBN: 9781945487156
[Image: 70837605176068713755.png]
This document guides specifiers, contractors, and concrete producers through the selection processes that identify methods for cold weather concreting. The objectives of cold weather concreting practices are to: a) prevent damage to concrete due to freezing at early ages; b) ensure that the concrete develops the recommended strength for safe removal of forms; c) maintain curing conditions that foster normal strength development; d) limit rapid temperature changes; and e) provide protection consistent with intended serviceability of the structure. Concrete placed during cold weather will develop sufficient strength and durability to satisfy intended service requirements when it is properly proportioned, produced, placed, and protected.
Keywords: accelerating admixtures; antifreeze admixtures; cold weather concreting; concrete temperature; curing; enclosures; form removal; freezing and thawing; heaters; heating aggregates; insulating materials; maturity testing; protection; strength development.
  â€¢ Dell_Brett, babakfeyzi, PinkPant, Umer.Aleem, milova
  Guide to proper concreting practices Part II - Placement, Compaction & Finishing ir_71 1 2,408 05-09-2023, 01:07 AM
Last Post: milova
  ACI 305.1: Specifications for Hot Weather Concreting nibbi 2 2,726 05-08-2023, 08:23 AM
  ACI KC-02: Guide to proper concreting practices Part I - Mixing and Curing ir_71 1 2,303 05-07-2023, 01:13 PM
  ACI 305R: Guide to Hot Weather Concreting poolmand 0 1,732 12-07-2021, 11:59 AM
