Civil Engineering Association eBooks Structural Books Steel Guide to Stability Design Criteria for Metal Structures: Ronald D. Ziemian
 carolinandra
Colombia
User ID: 12281
Threads: 112
Likes: 2,885 in 157 posts
Given Likes: 1333
#11
09-20-2012, 01:56 AM
Here is another link, it works in Adobe
[-] The following 15 users Like carolinandra's post:15 users Like carolinandra's post
  • mgdario, andersen3, zrilek, slowet, Jackass, stigtg, lednar_ved, malc, ali akbar, bigone, Mohammad6299, ting tsai huang, espresso, dinu69in, Aransam
 valinhas
Junior Member
Portugal
User ID: 759
Threads: 2
Likes: 73 in 16 posts
Given Likes: 533
#12
09-20-2012, 12:14 PM
Dear forum fellows, i do advise you to have both FoxitPhantom 5.4 and Adobe Acrobat Pro X, installed in your computer!
The way to solve this file reading case is to open the file with FoxitPhantom 5.4 software, do a recognizition of the text over all the file and save it . After you can read it with the latest Adobe Acrobat Pro X.
[-] The following 2 users Like valinhas's post:2 users Like valinhas's post
  • andersen3, pedzaquino
Threads: 830
#13
10-20-2013, 10:42 PM
Guide to Stability Design Criteria for Metal Structures, 6 edition
Author: Ronald D. Ziemian | Size: 27,5  MB | Format: PDF | Quality: Unspecified | pages: 2010 | ISBN: 0470085258
The definitive guide to stability design criteria, fully updated and incorporating current research
Representing nearly fifty years of cooperation between Wiley and the Structural Stability Research Council, the Guide to Stability Design Criteria for Metal Structures is often described as an invaluable reference for practicing structural engineers and researchers.
For generations of engineers and architects, the Guide has served as the definitive work on designing steel and aluminum structures for stability. Under the editorship of Ronald Ziemian and written by SSRC task group members who are leading experts in structural stability theory and research, this Sixth Edition brings this foundational work in line with current practice and research.
The Sixth Edition incorporates a decade of progress in the field since the previous edition, with new features including:
Updated chapters on beams, beam-columns, bracing, plates, box girders, and curved girders. Significantly revised chapters on columns, plates, composite columns and structural systems, frame stability, and arches
Fully rewritten chapters on thin-walled (cold-formed) metal structural members, stability under seismic loading, and stability analysis by finite element methods
State-of-the-art coverage of many topics such as shear walls, concrete filled tubes, direct strength member design method, behavior of arches, direct analysis method, structural integrity and disproportionate collapse resistance, and inelastic seismic performance and design recommendations for various moment-resistant and braced steel frames
Complete with over 350 illustrations, plus references and technical memoranda, the Guide to Stability Design Criteria for Metal Structures, Sixth Edition offers detailed guidance and background on design specifications, codes, and standards worldwide.
This post has been made by CivilEA Post-Generator v2.2.0[url=http://postgen.civilea.com/index.html][/url]
  • Jackass, draluka, bigone, Mohammad6299
 valinhas
Junior Member
Portugal
User ID: 759
Threads: 2
Given Likes: 533
#14
10-21-2013, 05:39 PM (This post was last modified: 10-21-2013, 06:02 PM by valinhas.)
If you are not able to open pdf file with Adobe Acrobat, install and use FoxitPhantomPDF software and most of your dificulties with PDF files will be solved.
[-] The following 11 users Like valinhas's post:11 users Like valinhas's post
  • oanm2000, mgdario, eliseo.as, jcbv, maijuji, bigone, Mohammad6299, zrilek, ting tsai huang, milova, malc
 bigone
User ID: 4505
Threads: 92
Likes: 5,722 in 517 posts
Given Likes: 7145
#15
03-20-2014, 10:11 AM
Guide to Stability Design Criteria for Metal Structures by Ronald D. Ziemian_6th Ed-2010-0470085258_AISC.pdf
Size: 28 MB, Pages: 1117
[-] The following 9 users Like bigone's post:9 users Like bigone's post
  • Mohammad6299, jcbv, PinkPant, Dell_Brett, eliseo.as, gulilero, bridgeengineer, yanburak, malc
 Dell_Brett
Admin Deputy
Admin Deputy
Brazil
User ID: 4
Threads: 264
Likes: 19,035 in 2,188 posts
Given Likes: 42492
#16
08-30-2015, 09:19 AM
Note: For hulkload site no manager is necessary! If request, ignore it!
  • amindoxiti, melekeen, gulilero, zrilek, oanm2000, ykhackhack
 gulilero
Italy
User ID: 14057
Threads: 113
Likes: 4,989 in 647 posts
Given Likes: 6732
#17
08-30-2015, 03:03 PM
[-] The following 8 users Like gulilero's post:8 users Like gulilero's post
  • zrilek, oanm2000, malc, emmi, ykhackhack, PinkPant, jcbv, dinu69in
 PinkPant
Turkey
User ID: 25448
Threads: 66
Likes: 4,007 in 374 posts
Given Likes: 10354
#18
03-02-2016, 02:33 PM
Guide to Stability Design Criteria for Metal Structures, 6th Edition
Author(s)/Editor(s): Ronald D. Ziemian | Size: 28 MB | Format: PDF | Quality: Unspecified | Publisher: WILEY | Year: 2010 | pages: 1117 | ISBN: 9780470085257
[Image: 62354767538783122138.jpg]
The definitive guide to stability design criteria, fully updated and incorporating current researchRepresenting nearly fifty years of cooperation between Wiley and the Structural Stability Research Council, the Guide to Stability Design Criteria for Metal Structures is often described as an invaluable reference for practicing structural engineers and researchers. For generations of engineers and architects, the Guide has served as the definitive work on designing steel and aluminum structures for stability. Under the editorship of Ronald Ziemian and written by SSRC task group members who are leading experts in structural stability theory and research, this Sixth Edition brings this foundational work in line with current practice and research.The Sixth Edition incorporates a decade of progress in the field since the previous edition, with new features including:Updated chapters on beams, beam-columns, bracing, plates, box girders, and curved girders. Significantly revised chapters on columns, plates, composite columns and structural systems, frame stability, and archesFully rewritten chapters on thin-walled (cold-formed) metal structural members, stability under seismic loading, and stability analysis by finite element methodsState-of-the-art coverage of many topics such as shear walls, concrete filled tubes, direct strength member design method, behavior of arches, direct analysis method, structural integrity and disproportionate collapse resistance, and inelastic seismic performance and design recommendations for various moment-resistant and braced steel framesComplete with over 350 illustrations, plus references and technical memoranda, the Guide to Stability Design Criteria for Metal Structures, Sixth Edition offers detailed guidance and background on design specifications, codes, and standards worldwide.
PinkPant
[-] The following 10 users Like PinkPant's post:10 users Like PinkPant's post
  • zrilek, blaze, temp1366, Dell_Brett, slowet, psk62, coxxxyboy, oanm2000, simanta, andre85
Pages (2): « Previous 1 2
  Seismic Design Guide for Metal Building Systems RyanRS 6 6,428 12-30-2025, 09:47 AM
Last Post: concreteok
  Design guide for concrete-filled double skin steel tubular structures carolinandra 0 1,688 04-16-2019, 04:02 PM
Last Post: carolinandra
  Stability and Ductility of Steel Structures (SDSS’99) abudabeeja 5 5,379 06-06-2018, 02:48 PM
Last Post: febo927
  Design guide for Wind loads on Unclad framed building structures dinu69in 2 3,858 02-27-2017, 10:10 PM
  ECCS No022 Manual on Stability of Steel Structures david-smith 2 3,440 07-28-2016, 02:26 PM
  Metal Building Systems: Design and Specifications abudabeeja 9 8,742 01-19-2016, 03:36 PM
Last Post: ibg0203
  Guide to Design Criteria for Bolted and Riveted Joints (2ed) Ultra Zone 4 4,386 12-16-2015, 05:42 PM
Last Post: cargadory2k
