Civil Engineering Association eBooks Structural Books Steel National Structural Steelwork Specification for Building Construction
Threads: 1,298
03-18-2011, 12:59 PM
Size: 2.3 MB | Format: PDF | Publisher: The BCSA | Year: 2007 | pages: 76 | ISBN: 085073052X
[Image: 23294637110114667846.jpg]
This Specification deals with structural steelwork designed in accordance with: BS 5950-1 Structural use of steelwork in buildings: Code of practice for design: rolled and welded sections
BS EN 1993-1-1 Eurocode 3: Design of steel structures – Part 1.1: General rules and rules for buildings
It can be used for all types of building construction designed for static loading. It is not intended to be used for steelwork in dynamically loaded structures or if fatigue is a factor unless appropriate amendments are made. The Specification describes the information to be included in a Project Specification, and also covers materials, preparation of drawings, fabrication, erection and the requirements for protective treatment including standard paint coatings. Specific requirements are placed on the Steelwork Contractor and the Employer. Other requirements are allocated to the Engineer, who may not be directly a party to the steelwork contract, but may be engaged by the Employer or by the Steelwork Contractor. It should also be noted that in certain design-build contracts design responsibility is shared and in these instances the role of Engineer will have to be allocated. This Specification should be introduced into a steelwork contract by a Project Specification, the contents of which are described herein. The Project Specification should also include any additions or modifications that may be required to the National Structural Steelwork Specification by the Employer for a particular contract if the form of behaviour or other aspects of the structure are unorthodox.
[-] The following 22 users Like ir_71's post:22 users Like ir_71's post
  • kowheng, malc, seriousboy, knrsa, toa011, vardan, usman, jcbv, zrilek, blaze, mowafi3m, jferrer, oanm2000, almadar12, cheo.smith, zainseiya, robertsas, Nilupa, baikur, simanta, kmmh76, TAFATNEB
Threads: 54
11-15-2012, 01:35 PM (This post was last modified: 11-16-2012, 09:23 AM by lisine.)
links dead; reposted direct links
version 2007
CE Making Version - october 2010
another link for both files
word
  • Dell_Brett, Trishu999, malc, zrilek
  Structural Design Guide: To the AISC (LRFD) Specification for Buildings amindoxiti 1 2,836 11-11-2017, 10:48 PM
Last Post: civilfafa
  Introduction to the Economics of Structural Steelwork mastermind 4 4,094 02-15-2017, 12:28 AM
Last Post: RyanRS
  Structural steelwork: analysis and design abudabeeja 9 7,800 12-04-2015, 08:09 PM
Last Post: cargadory2k
  Structural Steelwork: Design to Limit State Theory: T.J. MacGinley, T.C. Ang babak 9 8,081 11-10-2015, 02:37 AM
Last Post: ibg0203
  Structural steelwork connections abudabeeja 4 6,372 09-13-2014, 07:49 PM
  Semi-Rigid Joints in Structural Steelwork amindoxiti 1 2,358 09-12-2014, 07:35 PM
Last Post: Saze808
  Limit States Design of Structural Steelwork - by David Nethercot abudabeeja 7 7,832 07-13-2014, 03:39 PM
Last Post: i_kabir
