Civil Engineering Association eBooks Structural Books Steel Portal frame - eaves moment connection
 mowafi3m
Egypt
User ID: 1236
Threads: 385
Likes: 9,317 in 676 posts
Given Likes: 1667
01-17-2011, 07:32 AM (This post was last modified: 01-17-2011, 12:38 PM by oanm2000.)
Portal frame - eaves moment connection (example )
[Image: 83367938763085714014.jpg]
This example presents a method for calculating the moment resistance and the shear resistance of an eaves moment connection, as well as the design of welds. For the calculation of the moment resistance a simplified conservative method is used, which makes possible to avoid the calculation of bolt row groups. The connection is a Category A: Bearing type bolted connection using non-preloaded bolts.
[-] The following 31 users Like mowafi3m's post:31 users Like mowafi3m's post
  • ssi3k, narendra, robertsas, lednar_ved, dinu69in, blaze, kowheng, vardan, oanm2000, Quantumm, usman, brass, jferrer, zrilek, sodapas, Administrator , sangen, zainseiya, cesar3226, cristi, foxxx2010, tamboon, Nilupa, baikur, simanta, kmmh76, engrezi, andersen3, Pinkto, gulilero, yanburak
  Example in portal frame from A to Z mowafi3m 2 3,175 05-31-2018, 10:43 AM
Last Post: malee
  SCI P397: Elastic design of single-span steel portal frame buildings to Eurocode 3 Dobblo 0 1,994 05-13-2016, 12:35 PM
Last Post: Dobblo
  Purlins, Rails & Eaves Beams Design Guide mowafi3m 0 1,914 04-23-2016, 08:00 PM
Last Post: mowafi3m
  Recommended Seismic Design Criteria for New Steel Moment-Frame Buildings asim99 0 1,919 01-16-2013, 12:47 AM
  Eurobuild in Steel - Comparison of the Design of a Portal Frame ir_71 1 2,747 11-22-2012, 05:50 AM
  Design of Portal Frame Buildings Dell_Brett 4 6,208 07-24-2012, 06:30 AM
Last Post: shadabg
  Modification of Existing Welded Steel Moment Frame Connections for Seismic Resistance we_mbm 0 1,705 02-07-2012, 02:00 PM
Last Post: we_mbm
