Civil Engineering Association eBooks Codes, Manual & Handbook EN EN 10088 Stainless Steel standard series
10-22-2010, 05:10 AM (This post was last modified: 05-21-2012, 03:47 PM by 3fan.)
EN 10088-1:2005 Stainless steels - Part 1: List of stainless steels
This document lists the chemical composition of stainless steels, which are subdivided in accordance with their main properties into corrosion resisting steels, heat resisting steels and creep resisting steels and specified in the European Standards given in Table 1 (...).
Reference data on some physical properties are given in Tables A.1 to A.8.
NOTE 1 A matrix that shows which steels are included in which standard is given in Annex D.
NOTE 2 Valve steels are specified in EN 10090.
NOTE 3 Steel castings are specified in various European Standards (see Bibliography).
NOTE 4 Tool steels are specified in EN ISO 4957.
NOTE 5 Welding consumables are specified in various European Standards (see Bibliography).
EN 10088-2:2005
Stainless steels - Part 2: Technical delivery conditions for sheet/plate and strip of corrosion resisting steels for general purposes
1.1 This part of EN 10088 specifies the technical delivery conditions for hot or cold rolled sheet/plate and strip of standard grades and special grades of corrosion resisting stainless steels for general purposes.
NOTE General purposes include the use of stainless steels in contact with foodstuffs.
1.2 The general technical delivery conditions specified in EN 10021 apply in addition to the specifications of this European Standard, unless otherwise specified in this European Standard.
1.3 This European Standard does not apply to components manufactured by further processing of the product forms listed in 1.1 with quality characteristics altered as a result of such further processing.
EN 10088-3:2005 Stainless steels - Part 3: Technical delivery conditions for semi-finished products, bars, rods, wire, sections and bright products of corrosion resisting steels for general purposes
1.1 This part of EN 10088 specifies the technical delivery conditions for semi-finished products, hot or cold formed bars, rods, wire, sections and bright products of standard grades and special grades of corrosion resisting stainless steels for general purposes.
EN 10088-4:2009 Stainless steels - Part 4: Technical delivery conditions for sheet/plate and strip of corrosion resisting steels for construction purposes
1.1 The scope of this part of EN 10088 is to specify the technical delivery conditions for hot or cold rolled sheet/plate and strip of standard and special grades of corrosion resisting stainless steels for construction purposes in addition to the general technical delivery conditions specified in EN 10021.
1.2 This European Standard does not apply to components manufactured by further processing of the product forms listed in 1.1 with quality characteristics altered as a result of such further processing.
EN 10088-5:2009 Stainless steels - Part 5: Technical delivery conditions for bars, rods, wire, sections and bright products of corrosion resisting steels for construction purposes
1.1 The scope of this part of EN 10088 is to specify the technical delivery conditions for hot or cold formed bars, rods, wire, sections and bright products of standard and special grades of corrosion resisting stainless steels for construction purposes in addition to the general technical delivery conditions specified in EN 10021.
  â€¢ kowheng, jcbv, Grunf, Dell_Brett, st77bel, toa011, cordoba123, jferrer, ziggywas1, roaming79, chenamoy, jocagalhao, dbsimon29, jmpkumara, peixoto
Threads: 49
11-20-2012, 09:55 AM
here are the links for 1,2,3 ,5
pass:
part 4 is here:
if anyone can upload part 4 from scribd, please complete this post, because I cant download from scribd "premium" account
  â€¢
 lisine
Vanuatu
User ID: 17927
Threads: 265
Likes: 11,713 in 1,307 posts
Given Likes: 4631
11-20-2012, 10:19 AM
Part 4
All 5 parts
[-] The following 13 users Like lisine's post:13 users Like lisine's post
  â€¢ andersen3, Jackass, warbeast, jcbv, blaze, Dell_Brett, st77bel, peixoto, zrilek, Gkatzogias, cervevit, agelos100, CAMSECT
  EN ISO 15630 Standard series Steel for the reinforcement and prestressing of concrete ir_71 5 6,359 02-15-2022, 08:36 AM
Last Post: zrilek
  EN 771 Standard series Specification for masonry units ir_71 4 6,054 02-13-2022, 10:59 AM
Last Post: CAMSECT
  EN 10028:2009 Flat Products Made of Steel for Pressure Purposes Standard series ir_71 1 2,521 03-12-2014, 05:50 PM
  EN 10244 Standard Series Steel wire and wire products - Non-ferrous metallic coatings ir_71 1 2,744 06-07-2013, 07:04 AM
  EN 10083:2006 Standard Series - Steels for quenching and tempering ir_71 0 2,400 10-23-2010, 02:27 PM
