Civil Engineering Association eBooks Codes, Manual & Handbook EN EN ISO 6892-1:2009 Metalic materials. Part 1:Method of test at room te Method of test
10-21-2010, 07:28 AM
EN ISO 6892-1:2009 Metalic materials. Part 1:Method of test at room temperature
ISO 6892-1:2009 specifies the method for tensile testing of metallic materials and defines the mechanical properties which can be determined at room temperature.
The tension strength of the steel is very important property for the civil engineer. I hope to be useful with this document to all of you.
  â€¢ Grunf, kowheng, st77bel, Dell_Brett, roaming79
03-14-2014, 04:58 PM
[-] The following 3 users Like ir_71's post:3 users Like ir_71's post
  â€¢ Mohammad6299, Dell_Brett, rusty
03-12-2016, 04:51 PM
New links for BS EN ISO 6892-1:2009
  â€¢ oanm2000, bridgeengineer, Dell_Brett, PinkPant, anfaga
  EN 12350-2:2009 Testing fresh concrete - Part 2: Slump-test ir_71 2 5,073 01-11-2021, 12:19 PM
  EN 1011-1:2009 Welding — Recommendations for welding of metallic materials Part 1: Ge ir_71 2 3,677 04-09-2017, 04:00 AM
  EN 1052 Methods of test for masonry ir_71 3 3,599 11-06-2015, 01:59 AM
Last Post: concreteok
  EN 1015 Methods of test for mortar for masonry ir_71 2 3,106 05-02-2014, 07:53 PM
  EN 520:2004 Gypsum plasterboards - Definitions, requirements and test methods ir_71 2 3,189 09-08-2011, 09:02 AM
  EN 15255:2007 Energy performance of buildings- Sensible room cooling load calculation datagap 0 2,006 12-30-2010, 02:04 PM
Last Post: datagap
  EN 2243 parts 1-4 Non-metallic materials - Structural adhesives - Test method ir_71 0 2,030 12-18-2010, 11:56 AM
