Civil Engineering Association eBooks Geotechnical Engineering Foundation & Geotechnics in general GROUND ANCHORS AND ANCHORED SYSTEMS
 fabske
User ID: 30349
Threads: 1
Likes: 12 in 2 posts
Given Likes: 11
10-14-2010, 08:06 PM (This post was last modified: 10-14-2010, 09:49 PM by Grunf.)
I do not know if this book exists on this forum. It is may best choice for anchors.
[-] The following 7 users Like fabske's post:7 users Like fabske's post
  â€¢ bhawk0, elitvdis, kaci, cristi, Evandrojr, zrilek, alibouafia
 Dell_Brett
Admin Deputy
Admin Deputy
Brazil
User ID: 4
Threads: 246
Likes: 19,035 in 2,188 posts
Given Likes: 42494
10-14-2010, 10:19 PM
This is an correlated post: (could be useful!)
  â€¢ Grunf, thebeatles, bhawk0, jcoronellr, oanm2000, zrilek
 Dell_Brett
Admin Deputy
Admin Deputy
Brazil
User ID: 4
Threads: 246
Given Likes: 42494
10-16-2010, 11:05 AM
Ground Anchors and Anchored Systems - Post #1 Complement
[Image: 11iohet.jpg]
[Image: abmnnn.jpg]
This document presents state-of-the-practice information on the design and installation of cementgrouted ground anchors and anchored systems for highway applications. The anchored systems discussed include flexible anchored walls, slopes supported using ground anchors, landslide stabilization systems, and structures that incorporate tiedown anchors.
This document draws extensively from the FHWA-DP-68-IR (1988) design manual in describing issues such as subsurface investigation and laboratory testing, basic anchoring principles, ground anchor load testing, and inspection of construction materials and methods used for anchored systems.
This document provides detailed information on design analyses for ground anchored systems. Topics discussed include selection of design earth pressures, ground anchor design, design of corrosion protection system for ground anchors, design of wall components to resist lateral and vertical loads, evaluation of overall anchored system stability, and seismic design of anchored systems. Also included in the document are two detailed design examples and technical specifications for ground anchors and for anchored walls.
(Images will be changed the imagehost as soon our image hosts but will corrected)
[-] The following 7 users Like Dell_Brett's post:7 users Like Dell_Brett's post
  â€¢ kowheng, Grunf, RedHorse, oanm2000, zrilek, toa011, drim_w3
 3fan
Romania
User ID: 29614
Threads: 141
Likes: 7,359 in 1,207 posts
Given Likes: 5546
09-23-2011, 10:47 PM (This post was last modified: 01-09-2012, 02:20 AM by BennyP.)
[-] The following 12 users Like 3fan's post:12 users Like 3fan's post
  â€¢ gatob, sashka.od, zrilek, toa011, alibouafia, harika, vkkr, peymanlord, Dell_Brett, hcardenas, jcbv, cepot
 3fan
Romania
User ID: 29614
Threads: 141
Given Likes: 5546
01-08-2012, 10:03 PM
DIRECT LINKS thumbup
[-] The following 9 users Like 3fan's post:9 users Like 3fan's post
  â€¢ Dell_Brett, Jackass, vvvv, subin91, albani, shadabg, pmg814, pmg814, ting tsai huang
  Ground anchors and anchored structures by Petros P Xanthakos abudabeeja 8 6,423 10-21-2015, 05:56 PM
Last Post: ibg0203
  Ground anchor systems tuanpecc1 3 3,820 09-05-2012, 06:42 AM
Last Post: shadabg
  GROUND ANCHORS Limelette test field results: PROCEEDINGS INTERNATIONAL SYMPOSIUM ir_71 2 2,859 04-06-2012, 02:29 PM
Last Post: killerbee
