Civil Engineering Association eBooks Books, Codes, Theses, Journals & Papers Request Archive [REQUEST] A Model Code for the Displacement-Based Seismic Design of Structures Editors: G.M. Ca
[Request] A Model Code for the Displacement-Based Seismic Design of Structures Editors: G.M. Ca
 dynaquake
User ID: 2409
Threads: 5
Likes: 3 in 1 posts
Given Likes: 12
09-22-2010, 09:24 AM
[Image: 80658815235992362083.gif]
This publication has been developed to provide guidance as to how the direct displacement-based design methodology can be codified. It is intended for insertion within the seismic requirements of a code, establishing how design forces can be obtained using a Direct Displacement-Based Design (DDBD) approach. The document has currently been drafted with reference to several clauses of Eurocode 8. This document is presented in a traditional “Code + Commentary” format, on a split two-column page. The commentary aims to generally clarify the code requirements and indicate references where the background and further discussion on the requirements can be found. The document is the product of a 3-year Italian research initiative into the displacement-based design and assessment of structures as part of the RELUIS (Rete dei Laboratori Universitari di Ingegneria Sismica) project. The bulk of the text and requirements in this code have been developed from the recommendations provided in the book on DDBD by Priestley et al. (2007) and from the work carried out by the various research units of RELUIS Linea IV. Currently the model code has been prepared for a specific range of building structures and bridges. Given the limited range of structures that could be considered to date, the model code does not yet cover all structural systems and materials. In addition, a number of novel recommendations have been proposed that are preliminary in nature because of the limited amount of experimental or analytical data on which they are based. Future versions of this document will look to refine the current recommendations and extend the guidelines to encompass a more complete range of structural systems. With this in mind, the Model Code is published as a draft subject to public enquiry. Readers are kindly invited to provide feedback on the design recommendations by December 1st 2009. The bulk of the text and requirements in this code have been developed from the recommendations provided in the book on Direct Displacement-Based Seismic Design of Structures by Priestley et al. (2007). In fact, this Model Code was developed using Chapter 14 of the book as a starting point. The editors therefore wish to extend special thanks to the first author of the book, Nigel Priestley, for his invaluable contributions to this work, without which the Model Code would never have been possible.
[-] The following 3 users Like dynaquake's post:3 users Like dynaquake's post
  • jpoly, faros3000, SCREAM7890
 miquan
Vietnam
User ID: 631
Threads: 204
Likes: 3,748 in 387 posts
Given Likes: 1331
10-03-2010, 03:46 AM
A Model Code for the Displacement-Based Seismic Design of Structures book is implementation for Displacement-Based Seismic Design of Structures book.
I'm also looking for it, but until now it's still not available in internet.
You can order through IUSS Press.
It's not expensive (only €15), but ship fee is a problem with me.
Anyone could buy and scan for other member.:clap:
[-] The following 1 user Likes miquan's post:1 user Likes miquan's post
  • parhyang
 david-smith
United States
User ID: 43924
Threads: 247
Likes: 4,023 in 582 posts
Given Likes: 1085
06-07-2012, 06:43 AM (This post was last modified: 06-07-2012, 06:44 AM by david-smith.)
just to refresh the topic, please if anyone have the book,share it to CIVILEA.Thanks
[-] The following 3 users Like david-smith's post:3 users Like david-smith's post
  • miquan, devilmaycry, SCREAM7890
 RyanRS
Indonesia
User ID: 32427
Threads: 188
Likes: 4,684 in 228 posts
Given Likes: 765
07-09-2014, 10:44 AM
You can download pdf here :
[-] The following 6 users Like RyanRS's post:6 users Like RyanRS's post
  • SCREAM7890, blaze, gulilero, miquan, malc, zrilek
  [REQUEST] Seismic Design of Precast/Prestressed Concrete Structures aslam 1 2,675 06-06-2019, 03:45 PM
Last Post: temp1366
  [REQUEST] Performance-Based Seismic Evaluation of Ping An International Finance Center ASEC 1 1,951 08-14-2017, 09:21 AM
Last Post: pezhmankhan
  [REQUEST] Journal of Applied Mechanics;A Model for Vortex Induced Oscillation of Structures s0p9015 2 2,732 09-19-2016, 05:51 AM
Last Post: xnr09
  [REQUEST] Dynamic Analysis of Skeletal Structures: Force and Displacement Methods and Iterativ Saze808 0 1,471 11-18-2014, 06:21 PM
Last Post: Saze808
  [REQUEST] Assessment of EC8 Provisions for Seismic Design Steel Structures apocalipse 0 1,569 09-12-2014, 05:06 PM
Last Post: apocalipse
  fib Bulletin No. 68: Probabilistic performance-based seismic design farhangt 0 1,695 03-02-2014, 06:09 PM
Last Post: farhangt
  [REQUEST] Performance-Based Plastic Design: Earthquake-Resistant Steel Structures fooad2013 0 1,638 12-25-2013, 07:59 PM
Last Post: fooad2013
