Civil Engineering Association eBooks Geotechnical Engineering Foundation & Geotechnics in general USDOT: Selection of Spread Footings on Soils to Support Highway Bridge Structures
 cargadory2k
Mexico
User ID: 3043
Threads: 78
Likes: 851 in 108 posts
Given Likes: 346
09-04-2010, 07:59 PM (This post was last modified: 01-05-2012, 08:04 PM by usman.)
[Image: 46251387885976525158.jpg]
Selection of Spread Footings on Soils to Support Highway Bridge February 2010
Author(s)
Naresh C. Samtani, PE, PhD, Edward A Nowatzki, PE, PhD and
Dennis R. Mertz, PE, PhD
Abstract
The FHWA believes that spread footings on soils are underutilized because designers encounter one or more
of the following obstacles: (a) limited knowledge of AASHTO/FHWA technical references that pertain to
spread footings on soils to support bridges; (b) limited knowledge of adequate performance data for spread
footings; © unrealistic tolerable settlement criteria; (d) overestimation of loads used to calculate settlement;
and (e) the use of conservative settlement prediction methods. These obstacles have resulted in institutional
biases and overly conservative and excessively costly institutional processes that lead to the unnecessary use
of costlier deep foundation systems.
The primary goal of this report is to promote the use of spread footings bearing on competent natural soils,
improved soils, and engineered fill materials as a routine alternative to deep foundations for support of
bridges by addressing the factors identified above. Documented performance data is used to make this case.
The report also presents powerful concepts such as construction-point analysis and angular distortions to
demonstrate the efficacy of using spread footings. Implementation of these concepts requires only that
conventional computations be taken one step further without any requirement for advanced computational
skills. The report presents sources of information that agencies and designers can use as references in their
project applications. The report contains comprehensive appendices that treat in detail many of the topics
discussed in the report. For example, one such appendix provides an introduction to Load and Resistance
Factor Design (LRFD) that permits a rational approach to the consideration of spread footings on soils as a
feasible alternative to deep foundations
Visit the website
[-] The following 12 users Like cargadory2k's post:12 users Like cargadory2k's post
  â€¢ civilteam, Dell_Brett, kowheng, robertsas, lamkin, Panjack39, netsonicyxf, oanm2000, fabiovic1, YeiYei, peymanlord, alibouafia
  TRL Report CR341: Highway Embankment over soft compressible soils elitvdis 3 3,788 03-06-2017, 01:55 PM
Last Post: scorpion07
  LARGE SCALE LOAD TESTS AND DATA BASE OF SPREAD FOOTINGS ON SAND mahyarov 0 1,565 11-12-2012, 09:12 PM
Last Post: mahyarov
  FIELD AND LABORATORY PERFORMANCE EVALUATION OF SPREAD FOOTINGS mahyarov 0 1,563 11-12-2012, 09:08 PM
Last Post: mahyarov
  Engineering Policy Guidelines For Design Of Spread Footings mahyarov 1 2,099 10-30-2012, 05:39 AM
Last Post: shadabg
  USDOT: Dynamic Compaction ir_71 3 2,895 10-28-2012, 06:23 AM
Last Post: mahyarov
  LRFD Design and Construction of Shallow Foundations for Highway Bridge Structures mahyarov 0 1,773 10-23-2012, 01:12 PM
Last Post: mahyarov
  USDOT: Micropile Design and Constrction elitvdis 5 5,822 09-29-2012, 06:12 AM
Last Post: shadabg
