Civil Engineering Association eBooks Structural Books Concrete Engineered Concrete Mix Design and Test Methods (Concrete Technology Series)
Threads: 150
Given Likes: 28542
05-12-2009, 12:35 AM (This post was last modified: 12-19-2011, 12:11 PM by Dell_Brett.)
[Image: 86676369295942813902.jpg]
By Irving Kett
Publisher: CRC
Number Of Pages: 248
Publication Date: 1999-11-29
ISBN-10 / ASIN: 0849322774
ISBN-13 / EAN: 9780849322778
Binding: Paperback
The Romans used an early type of concrete made with natural pozzuolanic cement more than 2,000 years ago. Today, Portland Cement Concrete is the most important material of construction. Yet few books, if any, exist that offer an in-depth analysis of the mixing and testing methods of this vital hydraulic cement. Until now that is. Engineered Concrete: Mix Design and Test Methods helps engineers, as well as laboratory technicians, grasp a better understanding of Portland Cement and Portland Cement Concrete. The book is divided into several sections, with the first, Mix Design Procedures, explaining how concrete batches are designed, mixed, and measured for various consistencies. Another section details the tests of the primary component materials of concrete other than water - namely Portland Cement, aggregates, and mortar - while the final section includes some of the fundamental concrete testing procedures for different strength parameters in conformity with the standards of the American Society for Testing Materials. While focusing solely on Portland Cement, the book also includes information on other hydraulic cementitious materials and additives because of their modern applications. Solidly researched and written, Engineered Concrete: Mix Design and Test Methods provides a clear understanding of mix design and testing of Portland Cement Concrete. As every civil engineer knows, it is the most versatile and important material of construction, and will probably remain so as far into the future as we can see.
[-] The following 20 users Like oanm2000's post:20 users Like oanm2000's post
  β€’ Administrator , Administrator , Dell_Brett, Dell_Brett, cristi, cristi, deltalead, deltalead, zrilek, zrilek, jpver, jpver, boycv, Galileo, pssst, ziadjordan, arunsmt, Sumatra, psk62, Nilupa
 cace-01
User ID: 15651
Threads: 433
Likes: 10,522 in 867 posts
Given Likes: 7468
05-19-2010, 06:11 AM
[Image: 89281685164875783839.jpeg]
This is Second Edition
Thanks to original uploaders
See what’s new in the Second Edition:
New coverage of the latest concrete technologies such as high-performance and lightweight concrete Several new tests and sample tearsheets Additional and updated data sheets
The body of the book is divided into several sections, with the first explaining how concrete batches are designed, mixed, and measured for various consistencies. Another section details the tests of the primary component materials of concrete other than waterβ€”namely Portland Cement, aggregates, and mortarβ€”while the final section includes some of the fundamental concrete testing procedures for different strength parameters in conformity with the standards of the American Society for Testing Materials. Solidly researched and written, the book supplies a fundamental understanding of cement, concrete, and mixing and testing methods that allow readers to produce the most economical combinations of concrete materials and satisfy performance requirements and specifications.
[-] The following 22 users Like cace-01's post:22 users Like cace-01's post
  β€’ Dell_Brett, toa011, kowheng, oanm2000, pssst, civilteam, henrycv, michaelsoe, robertsas, defmere, arrowstar, shaqee, zrilek, arunsmt, ziadjordan, rudyhera03, ska51, Ernest0, GMianG, vijayakumarr, labofrock, Nilupa
 uetian19
Member
User ID: 24842
Threads: 11
Likes: 213 in 24 posts
Given Likes: 1114
10-10-2010, 03:18 AM (This post was last modified: 10-10-2010, 04:36 AM by Dell_Brett.)
ENGINEERING CONCRETE MIX DESIGN METHODS
by : IRVING KETT
Β© 2010 by Taylor and Francis Group, LLC
CRC Press is an imprint of Taylor & Francis Group, an Informa business
No claim to original U.S. Government works
International Standard Book Number: 978-1-4200-9101-4 (Paperback)
The purpose of this book is to familiarize civil engineering and construction technology students with two of the most important materials of construction, Portland cement (PC) and Portland cement concrete (PCC). People frequently make the error of using these terms interchangeably. It is important to keep in mind that PC is a powder, while PCC is initially a plastic material and for the remainder of its life, a solid. A valid analogy is to compare PC to flour and PCC to bread. The book aims to assist students to gain an understanding of PC and PCC through the physical handling and testing of these materials in the laboratory environment. While the book was primarily written for use at the college level, it may also serve as a practical guide for the graduate engineer and laboratory technician.
The body of this book is divided into four sections. Section 1 explains how concrete batches are designed, mixed, and measured for various consistencies, which is explained in a special chapter titled β€œMix Design Procedures.” Section 2 details the tests of the primary component materials of concrete other than waterβ€” namely Portland cement, aggregates, and mortar. Section 3 includes some of the fundamental testing procedures in conformity with the standards of the American Society for Testing Materials (ASTM). Section 4 includes the various appendices, followed by an index of additional data sheets. There probably will never be enough laboratory time to complete all of the test procedures, even in a 15-week university semester.
Info added by Moderator
[-] The following 38 users Like uetian19's post:38 users Like uetian19's post
  β€’ shaqee, engrszb, Trishu999, kowheng, rendel_Β©, geotecnico, RANA WASEEM, parwez007, vardan, quatermain, civilsaol, HASH007, ziggywas1, toa011, barukai, draluka, planeti_x, mz55, cigutierrezg, cesar3226, adi04, oanm2000, Adam Smith, vvvv, engr1900, zrilek, foxxx2010, Nilupa, warbeast, Sumatra, psk62, sangen, Dell_Brett, gulilero, simanta, shadabg, blaze, knrsa
 niki102
User ID: 8143
Threads: 82
Likes: 2,495 in 189 posts
Given Likes: 845
08-05-2011, 04:45 PM
Engineering Concrete Mix Design Methods
Author: Irving Kett | Size: 5.3 MB | Format: PDF | Publisher: Taylor and Francis Group, LLC | Year: 2010 | pages: 249 | ISBN: 9781420091014
[Image: comments.png]
Reduced Size
MirroRS By CivilEA Uploader Team
[-] The following 17 users Like niki102's post:17 users Like niki102's post
  β€’ sodapas, Dell_Brett, malc, pedzaquino, oanm2000, Adam Smith, Gabemzaman, orambo, engr1900, Jackass, zrilek, foxxx2010, Nilupa, vensto, Sumatra, labofrock, shadabg
 ska51
User ID: 11535
Threads: 382
Likes: 9,406 in 1,251 posts
Given Likes: 4017
12-19-2011, 10:42 AM
by: Irving Kett
Password for last 2 links:
"Downstream is Weaker"
[-] The following 6 users Like ska51's post:6 users Like ska51's post
  β€’ Dell_Brett, warbeast, seriousboy, Sumatra, almadar12, Nilupa
 kvtasp
User ID: 7690
Threads: 60
Likes: 2,028 in 379 posts
Given Likes: 791
01-30-2012, 11:25 AM
[-] The following 2 users Like kvtasp's post:2 users Like kvtasp's post
  β€’ Dell_Brett, Nilupa
 david-smith
United States
User ID: 43924
Threads: 209
Likes: 4,023 in 582 posts
Given Likes: 1085
04-26-2012, 12:43 AM
[-] The following 2 users Like david-smith's post:2 users Like david-smith's post
  β€’ chenamoy, Nilupa
Threads: 154
01-30-2013, 09:03 AM
RAR : 3.6 mb
[-] The following 6 users Like shadabg's post:6 users Like shadabg's post
  β€’ Nilupa, Jackass, hazus, StaadEng, simanta, Willowdo
Threads: 274
Likes: 12,075 in 1,233 posts
02-25-2013, 06:07 PM
[-] The following 3 users Like pezhmankhan's post:3 users Like pezhmankhan's post
  β€’ Dell_Brett, Nilupa, isurya
  Computational Modelling of Concrete and Concrete Structures TAFATNEB 4 5,038 04-27-2024, 07:45 PM
Last Post: aleph177
  SS 674 : 2021 Fibre concrete – Design of fibre concrete structures tomtumx 1 2,342 12-31-2021, 10:39 PM
Last Post: civilfafa
  3D Concrete Printing Technology sabooryan 0 1,694 04-01-2020, 04:52 PM
Last Post: sabooryan
  Concrete Durability: A Practical Guide to the Design of Durable Concrete Structures carolinandra 1 2,267 05-01-2019, 03:06 AM
  Modern Prestressed Concrete: Design Principles and Construction Methods amindoxiti 2 3,551 07-16-2018, 08:26 PM
Last Post: febo927
  Advanced Concrete Technology vol 1 to 4: John Newmen, Ban Seng Choo babak 14 9,647 06-20-2018, 05:10 AM
Last Post: axcel
  High Tech Concrete: Where Technology and Engineering Meet ir_71 0 1,794 06-18-2017, 05:56 AM
