ETABS 2015 V15 - Printable Version +- Civil Engineering Association (https://forum.civilea.com) +-- Forum: Software (https://forum.civilea.com/forum-65.html) +--- Forum: Software Product (https://forum.civilea.com/forum-105.html) +---- Forum: Csi Products (https://forum.civilea.com/forum-41.html) +----- Forum: ETABS (https://forum.civilea.com/forum-177.html) +----- Thread: ETABS 2015 V15 (/thread-50338.html) |
CSI ETABS 2015 v15.2.0.1295 (x64) - PinkPant - 03-09-2016 CSI ETABS 2015 v15.2.0.1295 (x64)
Size: 504 MB The innovative and revolutionary new ETABS is the ultimate integrated software package for the structural analysis and design of buildings. Incorporating 40 years of continuous research and development, this latest ETABS offers unmatched 3D object based modeling and visualization tools, blazingly fast linear and nonlinear analytical power, sophisticated and comprehensive design capabilities for a wide-range of materials, and insightful graphic displays, reports, and schematic drawings that allow users to quickly and easily decipher and understand analysis and design results. From the start of design conception through the production of schematic drawings, ETABS integrates every aspect of the engineering design process. Creation of models has never been easier - intuitive drawing commands allow for the rapid generation of floor and elevation framing. CAD drawings can be converted directly into ETABS models or used as templates onto which ETABS objects may be overlaid. The state-of-the-art SAPFire 64-bit solver allows extremely large and complex models to be rapidly analyzed, and supports nonlinear modeling techniques such as construction sequencing and time effects (e.g., creep and shrinkage). Design of steel and concrete frames (with automated optimization), composite beams, composite columns, steel joists, and concrete and masonry shear walls is included, as is the capacity check for steel connections and base plates. Models may be realistically rendered, and all results can be shown directly on the structure. Comprehensive and customizable reports are available for all analysis and design output, and schematic construction drawings of framing plans, schedules, details, and cross-sections may be generated for concrete and steel structures. ETABS provides an unequaled suite of tools for structural engineers designing buildings, whether they are working on one-story industrial structures or the tallest commercial high-rises. Immensely capable, yet easy-to-use, has been the hallmark of ETABS since its introduction decades ago, and this latest release continues that tradition by providing engineers with the technologically-advanced, yet intuitive, software they require to be their most productive.
[align=left] Code: *************************************** Code: *************************************** Code: *************************************** Code: *************************************** This post has been made by CivilEA Post-Generator V2.3.1
PinkPant RE: CSI ETABS 2015 v15.2.0.1295 (x64) - ALMF - 03-09-2016 I leave here direct links (no crack) 32 bits: -------- Code: *************************************** 64 bits: -------- Code: *************************************** Regards ALMF RE: CSI Etabs 2015 15.20 x64 - TAFATNEB - 03-20-2016 CSI ETABS 2015 version 15.2.0 | 1.0 Gb
Size: 1 GB Computers and Structures, Inc. (CSI), leader in software tools for structural and earthquake engineering, has released 15.2.0 version of ETABS 2015 is a civil engineering program that design and analyse steel and concrete structures using finite element method. ETABS is an engineering software product that caters to multi-story building analysis and design. Modeling tools and templates, code-based load prescriptions, analysis methods and solution techniques, all coordinate with the grid-like geometry unique to this class of structure. Basic or advanced systems under static or dynamic conditions may be evaluated using ETABS. For a sophisticated assessment of seismic performance, modal and direct-integration time-history analyses may couple with P-Delta and Large Displacement effects. Nonlinear links and concentrated PMM or fiber hinges may capture material nonlinearity under monotonic or hysteretic behavior. Intuitive and integrated features make applications of any complexity practical to implement. Interoperability with a series of design and documentation platforms makes ETABS a coordinated and productive tool for designs which range from simple 2D frames to elaborate modern high-rises. ETABS 15.2.0 Enhancements: International Design Codes - Shear-Wall Design Report- Eurocode 2-2004 enhancement to report wall unbraced height used for computing pier buckling load capacity. - Material Library - Russian material library updated. - Slab/Beam Design - CSA S16-09 and CSA S16-14 enhancement limiting the total effective width of the slab to 1/4 the span of the beam and taking in account the amount of deflection caused by shrinkage of the concrete. Output and Display - Database tables reporting story and diaphragm maximum and average drifts. - Drifts now reported at brace locations. External Import/Export - Export of AutoCAD .dwg files for AutoCAD versions 2015 and 2016 now available. Enhanced Application Programming Interface (API) - Plugins written to access API (Application Programming Interface) now accessible within ETAB
[align=left] Code: *************************************** This post has been made by CivilEA Post-Generator V2.3.1
RE: CSI Etabs 2015 15.20 x64 - jamesmakeez - 03-23-2016 ETABS 2015 15.2.2 Build 1364
Size: 503 MB Release Notes: Code: *************************************** Code: *************************************** Code: *************************************** This post has been made by CivilEA Post-Generator V2.3.1
LINK CODE PROTECTED RE: CSI Etabs 2015 15.20 x64 - BennyP - 07-10-2016 New Key Generator for 15.2.2 version up to July 2017. Thanks to LAVteam. Code: *************************************** Use the forum standard password. RE: CSI Etabs 2015 15.20 x64 - Arigato - 08-25-2016 ETABS 2016, v16.0 Code: *************************************** RE: CSI Etabs 2015 15.20 x64 - jokerâ„¢ - 08-25-2016 ETABS 2016, v16.0 X32 (Setup file): Code: *************************************** RE: CSI Etabs 2015 15.20 x64 - Arigato - 10-27-2016 updated new version, v16.01 fixed some bugs in PBD dl links: Code: *************************************** RE: CSI Etabs 2015 15.20 x64 - saherboy - 12-14-2017 Is there any chance to get the crack extended? it is not working anymore |
