ETABS 2015 V15.0.0
ETABS 2015 V15.0.0
Size: @ 495 EACH MB
New Practical Automation of Performance-Based Design
Performance based design (PBD) updated to ASCE 41-13
Nonlinear static and nonlinear dynamic procedures
Nonlinear hinges in frames, BRB's and shearwalls
Automated BRB modeling (Star Seismic)
Shearwall Fiber Hinge
Wall Reinforcement Definition
Several new hysteresis options for nonlinear hinges
Bilinear Maxwell oil damper property
Friction-spring hysteretic damper property
Fast Nonlinear Analysis (FNA) implemented for nonlinear hinges
Quasi-static (Dynamic) option for Static Pushover analysis
D/C ratio plots and tables for PBD
Output averaging over several time history runs
Shearwalls
Demand/Capacity Ratios
PBD Results
New Graphical User Interface
Fast DirectX graphics with full display, drafting and selection capability.
Customization of toolbar and shortcut keys.
New Advanced Modeling Options
Spectral matching of time history functions
Multiple mass sources for nonlinear analysis
Modification of geometry by mode shapes for imperfection analysis
Artificial Earthquake Generation
Frequency Content Matching
Mulitple Mass Sources
New International Frame Design Codes
Composite Beam Design - Enhanced User’s Interface
Composite Frame Design - Canadian CSA S16-14
Concrete Frame Design - ACI 318-14, CSA A23.3-14, and KBC 2009
Steel Frame Design - CSA S16-14, and KBC 2009
Composite Beam Design Checks
New International Shear Wall Design Codes
Design Codes: ACI 318-14, CSA A23.3-14, and KBC 2009
New International Loading Specifications
Automated response-spectrum functions for Argentina, Chile, Colombia, Dominican Republic, Ecuador, Guatemala, Mexico, Peru, and Venezuela
Enhanced Application Programming Interface (API)
Additional API support for design data and results
[Image: homepage.png]
KeyGenerator curtesy of raduga_fb from Lavteam.
Use forum's mandatory password.
Dear Moderator
ESET NOD 32 recognize it as a virus.
“His blue eyes are often bloodshot, and their expression indicates that there is a helpless, baffled soul squirming around inside this doughty fortress.” Prue by Alice Munro, ©1982.
[-] The following 4 users say Thank You to ssobhan for this post:
  • oanm2000, bigone, farzad1988, LiviuM
KG just worked fine for me (maybe wrong alert from AV)
[-] The following 1 user says Thank You to nmtuance for this post:
  • oanm2000
Working ok
In 24 hours i suppose many thousands around the world after using it found nothing. Many antivirus software identfy packed files as virus and is not the first one. You must use antivirus but don't believe the famous and the expensive are better. Many slow down the computer and vaste your time asking questions most users have no idea how to answer. After using a lot (i bought my first IBM PC 31 years ago) and the viruses begun to spreed after a short time i'm using a free one and don't care about sofisticated firewalls, malware hunters etc.. It's true, every 2-3 months i restore a clean image because installing and unistalling programs the disk is full of junk and is faster and safer to do that. Search the forum and will find other users complaining about virus alerts.
The answer is always - disable the antivirus when using or don't use the program. Buy Etabs and no need for Keygenerator.
Links for x32 and x64 including the medicine.
CSI ETABS 2015 version 15.0
[Image: 73828680250347435427.jpeg]
omputers and Structures, Inc. (CSI), leader in software tools for structural and earthquake engineering, has announced the new release of ETABS 2015, is a civil engineering program that design and analyse steel and concrete structures using finite element method.
ETABS 2015 provides an unequaled suite of tools for structural engineers designing buildings, whether they are working on one-story industrial structures or the tallest commercial high-rises. Immensely capable, yet easy-to-use, has been the hallmark of ETABS since its introduction decades ago, and this latest release continues that tradition by providing engineers with the technologically-advanced, yet intuitive, software they require to be their most productive.
ETABS 2015 Enhancements:
Performance Based Design (PBD) is a major shift from traditional structural design concepts and represents the future of earthquake engineering. These new procedures help assure that the design will reliably meet a desired level of performance during a given earthquake.
The fundamental component of PBD is nonlinear dynamic analysis where an attempt is made to capture the real behavior of the structure by explicitly modeling and evaluating post-yield ductility and energy dissipation when subjected to earthquake ground motions. ETABS 2015 introduces new special purpose options and algorithms for the practical and efficient application of these procedur
[-] The following 13 users say Thank You to TAFATNEB for this post:
  • ykhackhack, bigone, MOSS2000, PinkPant, shark, cenlara, oanm2000, viet2010, jaimar50, tooraj41, lesgiu, K.Lee, ting tsai huang
Hello,
about the virus warning, it's because the anvirus is detecting that the file in question is protected (encrypted/packed) from decompilation and code analysis using a hacked commercial tool called VMProtect.
The author of the file (raduga_fb, LAVTeam) most likely protected this file.
Maybe some antivirus like Kaspersky perform behaviour analysis while others just judge the file by the signature.
Try running it in virtual machine or in a sandbox.
With so many doctors there's nobody sick in this world.
[-] The following 12 users say Thank You to LiviuM for this post:
  • pezhmankhan, zrilek, concreteok, cace-01, PinkPant, RyanRS, oanm2000, melekeen, Dell_Brett, Diquan, bigone, mecheil.edwar
CSI.ETABS.2015-Rev2
[Image: 01698560347570535949.png]
Some new features were added to licgen. All archives are updated with this license generator. Read Readme.txt carefully specially concerning how to change program levels.
License valid till Midnight of Feb 14, 2016
CSI Etabs 2015 15.20 x64 BennyP 7 9,445 10-27-2016, 12:31 PM
Last Post: Arigato
CSI ETABS 2015 v15.2.0.1295 (x64) PinkPant 1 2,934 03-09-2016, 10:51 PM
Last Post: ALMF
