CSI SAP2000 V16.1
Current time: 05-11-2021, 02:39 PM
Author: aslam
Last Post: henchman2010
Replies 6
Views 12886
CSI SAP2000 V16.1
CSI SAP2000 V16.1
SAP2000 V16.1.0 Enhancements Subscribe RSS
Significant enhancements include:
Steel frame design has been added according to the Norsok N-004 2013 code.
Steel frame design according to the API RP 2A-WSD 21st edition code has been updated for supplements 1, 2 and 3.
Auto lateral wind load has been added according to the API 4F 2013 code.
The Chinese section-property database files have been enhanced by adding new sections.
A bilinear Maxwell damper has been implemented as a new link property. This device is a linear spring in series with a dashpot whose force-velocity relationship exhibits bilinear viscous behavior, typical of certain oil dampers having a relief valve.
A friction-spring hysteretic damper has been implemented as a new link property. The force-displacement relationship exhibits linear slipping stiffness when loading, but unloads with a smaller slipping stiffness. A pre-compression displacement and a displacement stop-limit may be specified.
The specification of the notional size used for time-dependent creep and shrinkage analysis has been enhanced to now be specified with the frame and shell section properties instead of with the material property.
A new staged-construction operation “Change Section & Age” is now available allowing specification of the “Age at Add” when changing frame sections or shell sections.
Table output can now request the correspondence between the response components at a single location for additive-, range-, and enveloping-type load combinations. Results that admit correspondence includes most displacement, force, and stress response quantities.
The import of primary data from SACS data files is now available.
[Image: homepage.png]
Present key works
[Image: 49697935711188048084.gif]
and using a little trick
[Image: 39351786316142481033.gif]
not for oegofdvfvn
[-] The following 12 users say Thank You to BennyP for this post:
  • rezart, seriousboy, oanm2000, ykhackhack, amareen2000, bprm, milvio, bigone, LiviuM, TAFATNEB, mgdario, mowafi3m
For people still searching echoid after versions 16.0 and 16.02 it's time to know the old KG (the script) is not for the new versions but the key posted in 16.0 and 16.02. For use
[-] The following 18 users say Thank You to BennyP for this post:
  • oanm2000, manzoor_quadri, learner20, Dell_Brett, bigone, hzaheer, LiviuM, MOSS2000, mowafi3m, TAFATNEB, jaxdes, taifur, Limpias72, azbukvid, golpesar, chairatpk, pram, pjcivil
Using a little trick is just date was change to 06-June-2012.
[-] The following 2 users say Thank You to raja for this post:
  • netsonicyxf, malee
Sorry to all, which is mentioned date is wrong, Actual the trick is 750 days back from 19-Jul-2014 (Which is generated by kg), So setting date back to 29-June-2012. This trick works also to Etabs 2013....
[-] The following 3 users say Thank You to raja for this post:
  • oanm2000, henchman2010, bigone
hi,
no it's wrong. Changing the date makes the software unvalaible. The trick of Sir BennyP is another thing much clever... We don't know what.
Best regards
An engineer must think of the worse, and he must do the best.
I can confirm raja post that adjusting the date backwards works for sap2000 16.1 and etabs 13.1.3
[-] The following 4 users say Thank You to henchman2010 for this post:
  • oanm2000, bigone, raja, milvio
