SAP2000 (Educational Version)
Current time: 03-02-2021, 09:55 PM
Author: joker™
Last Post: joker™
Replies 3
Views 7843
SAP2000 Educational
Size: 272, 272, 287, 625 MB
The purpose of this education module is to provide a medium for the integration of classical dynamics, computer modeling, and experimental testing. This goal is achieved by the analysis, modeling, and experimentally testing of a 4-story scale structure that was designed, fabricated, and experimentally tested using UCLA NEES equipment. The geometric details of the scale structure are displayed in the first section of the module. In the second section, an analytical model of the scale structure in the form of an idealized shear building will be constructed and analyzed to obtain modal properties and response quantities. In the third section, a computer model will be created using SAP2000 software in which modal properties and response quantities can readily be obtained and compared to results in the second section. In the third section, data from an actual experiment where the scale structure was attached to the mass of a linear shaker will be used to perform system identification, and again, results will be compared to previous sections.
SAP2000 Educational V12
SAP2000 Educational V14
SAP2000 Educational V14.2.4
SAP2000 Educational V15.0.1
No limits to creativity
[-] The following 11 users say Thank You to joker™ for this post:
  • David90, faxel, Fem.Ing, mybest, robox514, parhyang, Quantumm, anfaga, paitaconst, Clouseau, nickycruz
Hello riani151207 , You are welcome Cutesmile
The limits of the current educational versions is:
- for SAP2000 and ETABS - 30 joints for nonlinear problems and 100 joints for all other
- for SAFE – 250 joints
Joints are counted before and after meshing. Limit applies to both.
I have account from CSI to access to the site by FTP ,so I can Download Educational Version only for SAP2000 , any new of SAP2000 Edu I will share it
[-] The following 5 users say Thank You to joker™ for this post:
  • David90, mybest, parhyang, lam0101001, concreteok
i interested using educational version to verified a simple problems, since for some medicine did not work for specific case.
try to install edu version 12 & 14, give an error every start then programs end immideately. it looking for license as shown below, not as in case version 7
[Image: 57492045683813923426.png]
if anybody have, pls kindly shared. thx
Hello,
Educational Version no need crack or keygen , It is free because It is limited.
The problem cause you have installed SAP2000 StandAlone 30 days trial before you install education version.
[-] The following 1 user says Thank You to joker™ for this post:
  • parhyang
CSI SAP2000 22.0.0 EVALUATION VERSION tentaeste 0 1,607 01-30-2020, 10:56 PM
Last Post: tentaeste
CSI SAP2000 version 21.0.2 er.shyams 1 4,347 06-02-2019, 01:54 PM
Last Post: zrilek
Sap2000 Student Version 7.4 mybest 2 5,371 03-25-2012, 05:06 PM
Last Post: joker™
