guthrie.CAD2Shape v5.0.A.08
Current time: 10-23-2021, 04:20 PM
Author: henrybill
Last Post: henrybill
Replies 2
Views 3203
Convert AutoCAD DWG / DXF to ESRI Shape (.shp) -(ArcView, ArcGIS, ArcMap etc.)
- AutoCAD® DXF/DWG to ESRI Shapefile converter –
- Supports all AutoCAD versions up to AutoCAD 2010 -
[Image: 56709913426089254195.png]
[Image: 41975972764969768544.png]
Application developers, if you need output to ESRI shapefile format (and your software already has DXF / DWG output) this is the software module for you, all the hard work is already done!
CAD2Shape is a dwg and dxf converter that converts AutoCAD DWG and DXF files to ESRI SHP (shapefile) files.
Convert AutoCAD DXF/DWG files to ArcView/ESRI shapefile format. It is a stand alone CAD to Shapefile converter, translating all AutoCAD DXF and DWG versions up to and including AutoCAD 2010
CAD2Shape 5.0 converts: AutoCAD DXF/DWG drawing files to ESRI shapefile format files (ArcView, ArcGIS, ArcMap etc.)
CAD2Shape features::
• Stand-alone CAD to Shapefile conversion
• Optional translation to 2D or 3D shapefiles
• Attach Z value as 'Elevation' data
• Text to 'Labels Theme'
• Text to exploded polyline option. - allows direct translation of CAD Text to visible text in ArcGIS/ArcMap/ArcView. The resultant text and placement will be visually identical to that in the originating CAD drawing
• Attributes translation
• Translate holes / islands /donuts from originating CAD drawing to
• Polygon shapefile
• Extended Entity Data (Xdata) translation
• Translate 3D surfaces to MultiPatch shapefile types
• Filter by Layer, Area, Color, Entity
New features in version 5.0
• Translates all AutoCAD DXF and DWG versions up to and including AutoCAD 2010
• Option to output to raw data file: e.g. CAD to XYZ, CAD to CSV, CAD to BLN (Surfer Blanking file format)
• MPolygon support
• Dimensions/Leader/Tolerance support
• Additional XDATA types
• Length attribute for polylines
• Data suitable for import to Google Earth Pro (shapefiles), and Google Earth Plus (CSV)
[Image: tips.png]
Name: CAD2Shape 5.0 Rev A.08 AutoCAD DXF/DWG to Shapefile Converter.
• Released: 27 Oct 2010: ©1999-2010
• OS: MS Windows 2000/2003/2008/Citrix/XP/XP 64/Vista/Vista 64/Windows 7/Windows 7x64
• Requirements: No special requirements
• Publisher: Guthrie CAD/GIS Software
v5 is the latest version
New version : 6.0- Supports all AutoCAD versions up to AutoCAD 2012
The evaluation version of CAD2Shape is enabled for 15 days and for 20 large file translations (up to 10 MB). After the 15 day trial is up the software will still continue to work, but only for small files (<50K).
[Image: homepage.png]
[-] The following 2 users say Thank You to henrybill for this post:
  • malc, learner20
Reply
Dear henrybill,
Thanks for your useful post!
Some suggestions:
1- The post must be clear! If they have medicine (C*r*a*c*k*), in the tips it's unnecessary (and must be removed) the observation:
"... The evaluation version of CAD2Shape is enabled for 15 days and for 20 large file translations (up to 10 MB). After the 15 day trial is up the software will still continue to work, but only for small files (<50K). ..."
This observation only generates confusion!
2- All ScreenShots must be in English!. The program is multilingual and in our forum only English is allowable.
This post is temporary and will be removed.
regards
Dell Brett
[-] The following 2 users say Thank You to Dell_Brett for this post:
  • Grunf, learner20
Reply
Mr. Dell Brett
about their observations:
1. The application is not multi-language, the language of both the installation and use is in English, I'm using Windows in my native language and it is impossible to catch when this situation occurs.
In this case, i suggest that you use the Software Screenshots in Software Home page.
Imagine if a Chinese member do the same...
2. In the tips concerning that observation of the limitation was only informative, but later said that the medication is present.
As I sad, it's more confusing than informative. Consider don't use it!
thanks
You're welcome!
[-] The following 1 user says Thank You to henrybill for this post:
  • learner20
Reply
