Civil Engineering Association eBooks Codes, Manual & Handbook AISC AISC 327: Seismic Design Manual
 Dell_Brett
Admin Deputy
Admin Deputy
Brazil
User ID: 4
Threads: 264
Likes: 19,035 in 2,188 posts
Given Likes: 42487
#11
12-06-2019, 08:55 AM
Mirror Link:
[-] The following 11 users Like Dell_Brett's post:11 users Like Dell_Brett's post
  • pedzaquino, amindoxiti, Nita1391, lisine, cheosmith, zrilek, nhim4mat2006, simanta, jonygut, Hengki, ascetic19
 jonygut
Nicaragua
User ID: 175427
Threads: 7
Likes: 286 in 17 posts
Given Likes: 322
#12
09-10-2020, 05:04 PM (This post was last modified: 09-10-2020, 05:15 PM by jonygut.)
AISC - Seismic Design Manual 2ed - SHARING THE MISSING PAGES 4-16&4-17
  • Size: 341 KB
  • Quality: Unspecified
[Image: comments.png]
No password needed.
Size: 16.9 MB | Format: PDF | Quality: Original preprint
[Image: 58534677281303336328.jpg]
Better quality about the same manual already shared in here.
[-] The following 18 users Like jonygut's post:18 users Like jonygut's post
  • Veggeta, babakfeyzi, carolinandra, malc, PinkPant, jcbv, zrilek, temp1366, hatkam, kowheng, agelos100, oanm2000, ersin, Wijono, gulilero, cace-01, Dell_Brett, cargadory2k
Threads: 750
Likes: 8,267 in 1,354 posts
Given Likes: 88
#13
01-18-2022, 11:31 AM (This post was last modified: 01-18-2022, 11:41 AM by poolmand.)
AISC Seismic Design Manual AISC Seismic Design Manua (HQ)
| Size: 65.1 MB| Format: PDF| Quality: Original preprint| Publisher: American Institute of Steel Construction| Year: 2018| pages: 1832 | ISBN: 1564240355, 9781564240354
[Image: 86350815157894866180.jpg]
Format
In a change from the previous edition, the 3rd Edition Seismic Design Manual is produced with a high-quality vinyl softcover that coordinates with the 15th Edition Steel Construction Manual.
Contents
The c AISC Seismic Design Manual includes:
    Comprehensive design examples, updated for the 2016 AISC Seismic Provisions.
    Side-by-side LRFD and ASD design methodologies for design examples
    Thorough examples on connection design, including panel zone detailing and brace-to-beam/column connection design options
    Extended discussion and more economical design methodology for collector elements
    Examples for buckling-restrained braced frames
    Chapter listing:
        General Design Considerations
        Analysis
        Systems Not Specifically Detailed for Seismic Resistance
        Moment Frames
        Braced Frames
        Composite Moment Frames
        Composite Braced Frames and Shear Walls
        Diaphragms, Collectors and Chords
        Provisions and Standards
Also, included are two AISC seismic-related standards: the 2016 AISC Seismic Provisions for Structural Steel Buildings (ANSI/AISC 341-16) and the 2016 AISC Prequalified Connections for Special and Intermediate Steel Moment Frames for Seismic Applications (ANSI/AISC 358-16).
[-] The following 12 users Like poolmand's post:12 users Like poolmand's post
  • jcbv, babakfeyzi, cace-01, Dell_Brett, kowheng, malc, temp1366, bigone, jonygut, subin91, cheosmith, milova
 ASEC
United States
User ID: 13344
Threads: 15
Likes: 397 in 113 posts
Given Likes: 298
#14
04-19-2023, 02:01 PM
I would appreciate if anybody can post a working link for the AISC Seismic Design Manual 3rd Edition.
 zrilek
User ID: 3860
Threads: 12
Likes: 337 in 59 posts
Given Likes: 22023
#15
04-20-2023, 07:03 AM
The main link is working.
 cheosmith
Jamaica
User ID: 174720
Threads: 2
Likes: 44 in 23 posts
Given Likes: 499
#16
04-20-2023, 11:57 AM
(04-19-2023, 02:01 PM)ASEC Wrote: I would appreciate if anybody can post a working link for the AISC Seismic Design Manual 3rd Edition.
The mediafire link works
[-] The following 1 user Likes cheosmith's post:1 user Likes cheosmith's post
  • Dell_Brett
Threads: 750
Given Likes: 88
#17
06-13-2026, 09:27 AM
Seismic Design Manual (Fourth Edition)
| Size: 34.83 MB| Format: PDF| Quality: Original preprint| Year: 2024 | ISBN: 978-1-56424-104-7
This edition of the Seismic Design Manual contains more than 2,040 pages of seismic design information for steel structures. It includes hundreds of pages of comprehensive design examples, including connections, updated for the 2022 AISC Seismic Provisions. Examples are shown with LRFD and ASD design methodologies side-by-side.
This revision adds design examples for multi-tiered buckling-restrained braced frames, concentrically braced frame column bases, and connection design at the intersection of braces in a concentrically braced frame. Another updated example considers partial-joint-penetration groove welds for a column splice in a special moment frame.
New tables summarizes applicable requirements of the AISC Seismic Provisions as well as second-order amplifier values for use with approximate second-order analysis. An updated discussion of diaphragms considers load path, challenges in analysis, and common assumptions, along with guidance on diaphragm modeling.
Table of Contents
Analysis
Moment Frames
Braced Frames
Codes and Standards
Part 9 of this publication includes two seismic design standards. These are both available for free download in PDF format in Current Standards:
2022 AISC Seismic Provisions for Structural Steel Buildings (ANSI/AISC 341-22)
2022 AISC Prequalified Connections for Special and Intermediate Steel Moment Frames for Seismic Applications (ANSI/AISC 358-22).
[-] The following 7 users Like poolmand's post:7 users Like poolmand's post
  • subin91, zrilek, tuanpecc1, lisine, milova, babakfeyzi, temp1366
Pages (2): « Previous 1 2
  AISC - Steel Design Guides Administrator 75 82,999 06-13-2026, 09:38 AM
  AISC - Steel Construction Manual dinu69in 26 25,952 06-10-2026, 12:17 PM
  AISC 341: Seismic Provisions for Structural Steel Buildings ir_71 10 9,524 12-04-2023, 08:47 AM
  AISC 342: Seismic Provisions for Evaluation and Retrofit of Existing Structural temp1366 2 4,086 12-04-2023, 08:40 AM
  AISC 205: AISC Certification Program for Steel Bridge Fabricators Administrator 2 4,067 01-19-2022, 05:18 AM
  AISC Design Examples babak 16 11,377 01-18-2022, 12:50 PM
  AISC: Manual of Steel Construction LRFD - Vols. I & II - Second Edition Ultra Zone 3 6,655 01-18-2022, 11:09 AM
