Etabs 18.0.2, Sap2000 V21.1, Bridge v21.1.0, Detail V18.0
Current time: 06-03-2020, 04:05 AM
Author: faros3000
Replies 6
Views 2459
CivilEA users, please beware that the latest keygen posted for the following software
CSI ETABS 18.0.2
CSI SAP2000 V21.1
CSI Bridge v21.1.0
CSi Detail V18.0
clearly states that:
"NOTE: program has to be ONLINE (has access to the internet) otherwise program will not even start."
As CSI is now actively pursuing unlicensed users of its software, connecting the software online is a highly risky bet, unless you are in a country that does not have much cooperation with intellectual property enforcement agencies/organisms.
Information is not knowledge.
Albert Einstein
[-] The following 4 users say Thank You to faros3000 for this post:
  • versiondemo, cargadory2k, temp1366, ascetic19
Reply
As far as I've tested, ETABS & DETAIL run perfectly fine without internet access.
As for collecting remote data, it is illegal, unless with explicit permission from user. Maybe something is mentioned in EULA.
[-] The following 2 users say Thank You to temp1366 for this post:
  • faros3000, techno
Reply
I know the Dassault Systems policy with SolidWorks and they spy the use of cracked versions. With the main program, they install a software that sends the IP, Computer name, time of usage, serial number, etc... And they use this information to contact the "fraudulent" user offering him two posibilities:
a) Buy a full license of the program.
b) A demand for an important amount of money that they calculate based on the time that the user has been using the illegal software.
The express consent of the user is taken for granted when you accept the conditions to install the program, something we rarely read. So be aware on using cracked versions with internet access.
[-] The following 1 user says Thank You to versiondemo for this post:
  • faros3000
Reply
Can you use any software that prevents programs connect to the internet?
Reply
(10-05-2019, 05:56 AM)temp1366 Wrote: As far as I've tested, ETABS & DETAIL run perfectly fine without internet access.
Thanks for you comment.  Did you install it offline also, or needed to be online?
(10-05-2019, 05:56 AM)temp1366 Wrote: As for collecting remote data, it is illegal, unless with explicit permission from user. Maybe something is mentioned in EULA.
Not for software companies, nor for any american company in any case.  I mean, it might be illegal, but as they have the power to do so, they do.  You just don´t know where they got your data, they just sue when they know who and where you are.  (Think about Google).
(10-05-2019, 12:13 PM)versiondemo Wrote: I know the Dassault Systems policy with SolidWorks and they spy the use of cracked versions. With the main program, they install a software that sends the IP, Computer name, time of usage, serial number, etc...
Same policy used now by CSI, Autodesk and Tekla. And that´s how I got caught !
Albert Einstein
[-] The following 3 users say Thank You to faros3000 for this post:
  • temp1366, versiondemo, ascetic19
Reply
(10-05-2019, 08:30 PM)faros3000 Wrote: Thanks for you comment.  Did you install it offline also, or needed to be online?
on my notebook i installed it with active internet connection and on PC in offline because my pc is not connected to any network (Local Lan or internet)
On both of the ETABS working without any problem (seemingly)
(10-05-2019, 08:30 PM)faros3000 Wrote: Not for software companies, nor for any american company in any case.  I mean, it might be illegal, but as they have the power to do so, they do.  You just don´t know where they got your data, they just sue when they know who and where you are.  (Think about Google).
That is a huge problem and i don't know how it can be fixed. but as for me, I'm blocking every app (even does obtained legally) from accessing internet.
[-] The following 5 users say Thank You to temp1366 for this post:
  • faros3000, versiondemo, concreteok, ascetic19, kirankumarklk
Reply
Hello,
I installed both Etabs 18.0.2 and sap2000 V21.1 without an active internet connection. Although I disabled "native image generation", they are not slow at all. Finally, I performed a nonlinear time history analysis, pushover analysis, and design of a 2D steel frame without any problem. They sound OK.
Do not worry about your difficulties in Mathematics, I can assure you mine are still greater.  -Albert Einstein
[-] The following 10 users say Thank You to amindoxiti for this post:
  • promo8, Nita1391, faros3000, malc, temp1366, concreteok, cace-01, kirankumarklk, ascetic19, Dell_Brett
Reply
