components wallmesh - Printable Version +- Civil Engineering Association (https://forum.civilea.com) +-- Forum: CivilEA Shop (https://forum.civilea.com/forum-168.html) +--- Forum: Own-Copyrighted Material (https://forum.civilea.com/forum-170.html) +--- Thread: components wallmesh (/thread-58197.html) |
components wallmesh - wallmesh - 05-05-2024 What are the required components in the construction and installation of wallmesh? Among the main consumables, the following can be mentioned: Fiberglass mesh or wall mesh tape: Wallmesh tape is another name for fiberglass mesh, which is widely used in the implementation of wallmesh. The material of this type of mesh is glass composite type and has a high resistance against alkaline substances. Fiberglass mesh is a net shape that is widely used to implement the wall mesh method in the walls of buildings. Fiberglass mesh has advantages such as high adhesion, high flexibility, high resistance to play and alkaline environments, etc. In addition, the tensile strength of fiberglass mesh is very high. Cement plaster: Cement plaster is one of the best materials that is widely used for wall mesh. The material of this type of plaster is cement and it has high quality and durability. Cement plaster is used as a cover layer, and this product is very useful for installing fiberglass mesh. The most important application of this type of plaster is covering brick walls, block walls and concrete surfaces. This type of plaster is very suitable for use on internal and external surfaces. This type of plaster is applied with the help of trowel or spraying method on the surface of the wall which is meshed. If you use cement plaster, you should use alkali-resistant fiberglass mesh in the wall mesh system. Gypsum plaster: Another type of plaster that is widely used in the implementation of wall mesh system is gypsum plaster. This type of plaster is widely used for installing fiberglass mesh. To make this type of plaster, a combination of plaster, cement, sand and lime is used. Gypsum plaster has a very high adhesive strength and its implementation is possible easily. This type of plaster can be used as the best coating on the surface of the ceiling and internal walls and columns. If you use gypsum plaster, you should use E-Glass fiberglass mesh in the wall mesh system. Angle: Broken corner or stud corner is another material used in the implementation of wall mesh. This type of mesh wall corner is used to connect the frame and the wall. A broken corner or stud corner prevents the wall from moving in the opposite direction from the plane of the wall. As a result, the use of this type of corner prevents the wall from being damaged by various external factors such as shocks, earthquakes, etc. Epoxy glue: In addition to screws, dowels, and nails, epoxy glue is also used to make the corners in the upper and lower part of the wall. This type of glue has many advantages, that's why the use of this product has increased today. This type of glue has very little weight and its resistance to any pressure and impact is high. Epoxy glue consists of two different parts, resin and hardener. The resin part of this type of glue has adhesive properties and the hardening part has final hardening properties. |
