CSI SAP2000 V15 - Printable Version +- Civil Engineering Association (https://forum.civilea.com) +-- Forum: Software (https://forum.civilea.com/forum-65.html) +--- Forum: Software Product (https://forum.civilea.com/forum-105.html) +---- Forum: Csi Products (https://forum.civilea.com/forum-41.html) +----- Forum: SAP2000 (https://forum.civilea.com/forum-178.html) +----- Thread: CSI SAP2000 V15 (/thread-26750.html) |
RE: CSI SAP2000 v15 - BennyP - 08-15-2011 And other links: Code: *************************************** RE: CSI SAP2000 v15 - BennyP - 08-16-2011 More links: Code: *************************************** SAP2000 V15.0.1 - joker™ - 08-19-2011 SAP2000 V15.0.1 Size: 650 MB
Supported Operating Systems: Windows XP & Vista & 7 Newer Features The following list identifies changes made to the program since the prior release: More responsive graphical user interface, especially for the use of database tables Real-time analysis for smaller models Quick and easy generation of final printed reports Predefined reports, or fully user-customized reports Cover sheet Formatted tables of model definition, analysis and design results Graphical displays Detailed design sheets Improved automated load combinations for design AISC 360-05/IBC2006 steel-frame design code, with seismic provisions Direct Analysis Method of AISC 360-05 code Includes small P-delta effect Automated inclusion of stiffness modification factors, with user control Design-decision guidance on when Direct Analysis Method is needed CAN/CSA-S16-01 steel-frame design code, with seismic provisions Enhanced design of eccentrically braced frames for AISC 360-05/IBC 2006 and CAN/CSA-S16-01 steel-frame design codes Canadian NBCC 2005 wind loads, seismic loads, and response-spectrum functions Load combinations can be converted to nonlinear load cases for advanced design Enhanced display of failure modes for steel-frame design DirectX graphics Hyperstatic analysis for secondary prestress forces Staged construction enhancement Control by individual objects as well as by group Frame end releases can be changed Property modifiers for frames, tendons, and shells can be changed Section properties for frames, tendons, and shells can be changed Enhanced Section Designer More control over material properties, including Mander model for all sections Overlapping shapes allowed Improved Boolean operations Frame element fiber hinges for arbitrary sections can be defined using Section Designer External tools developed by dealers and third parties can be accessed in SAP2000 OpenAPI functionality is complete and available without additional license Users can add their own documents to be accessed through the SAP2000 Help menu Export of geometry and element connectivity to CSI Perform-3D Enhanced import of STAAD models MODELING (A, P, B) • Object Based Graphical Interface • Model Templates with Auto Meshing • Frame, Cable and Tendon Members • Area (Shell) and Solid Objects with Internal Meshing • Integrated Graphical Section Designer for Complex Frame Shapes • Bridge Wizard for Bridge Modeling (A, P, BR) • Editing with Move, Merge, Mirror and Replicate • Accurate Dimensioning with Guidelines and Snapping • Auto Edge Constraints for Mismatched Shell Meshes • Quick Draw Options for Object Creation • Tendons in Frame, Shell and Solid Objects • Parametric Bridge Cross Sections (A, P, BR) • Support for Multiple Coordinate Systems • Powerful Grouping and Selection Options • Definition of Highway Layout Lines (A, P, BR) • Automatic Generation of Code Lateral Wind and Seismic Loads • Wind Loads on Open Structures • Transfer of Loads from Area Objects to Framing Systems • Application of Lane Loads to Bridge (A, P, BR) • Cracked Properties – Property Modification Factors • Gravity, Pressure and Thermal Loading • Line and Surface Multi-Linear Springs (A) • Staged Construction Analysis (A, SC) • Wave Generator (A, OS) • Parametric Tendon Layout for Box Girders (A, P, BR) SAP2000 ANALYSIS • Static Analysis with Frame and Shell Objects (A, P, B) • Response Spectrum Analysis with Eigen or Ritz Vectors (A, P, B) • P-Delta Analysis (A, P, B) • Joint Constraints including Rigid Bodies & Diaphragms (A, P, B) • Applied Force and Displacement Loading (A, P, B) • Gravity, Pressure and Thermal Loading (A, P, B) • Layered Shell Element (A, P, B) • Post Tensioning in Frame, Area and Solid Objects (A, P, B) • Relaxation & Anchorage Slip Losses in Tendons (A, SC) • Plane, Asolid and Solid Objects (A, P) • Time History Analysis, including Multiple Base Excitation (A, P) • Frequency Domain Analysis – Power Spectral Density (A, P) • Moving Loads (A, P, BR) • Time Dependent Concrete Creep & Shrinkage Effects (A, SC) • Frame Hinges for Axial, Flexural, Shear & Torsional Behavior (A) • Nonlinear Static Pushover Analysis (A) • Viscous Dampers (A) • Fiber Hinges (A) • Base Isolators (A) • Gap Object for Structural Pounding (A) • Time History with Wilson FNA or Direct Integration Methods (A) • Dynamic Effects of Moving Loads (A, P, BR) • Segmental Construction Analysis (A, SC) • API Simplified Fatigue Analysis (A, OS) BUCKLING • Buckling Analysis Around Any Nonlinear State (A) • Element-Based P-Delta Effects for Local Buckling Instabilities (A) LARGE DISPLACEMENTS • Large Displacement/Small Strain Analysis (A) • Nonlinear Large Rotations Cable Analysis (A) FREQUENCY DOMAIN • Steady State Analysis (A, P) • Power Spectral Density (PSD) Analysis (A, P) • Frequency Dependent Properties for Links/Supports (A, P) NONLINEAR MATERIAL BEHAVIOR • Pushover Analysis Using Fiber Models (A) • Viscous Damper with Nonlinear Exponent on Velocity Term (A) • Base Isolator with Biaxial Plasticity Behavior (A) • Hinges offer P-M-M Interaction with Moment-Curvature (A) • Section Designer – Mander Model for Confined Concrete (A) • Pivot-Hysteresis and Takeda Models for Plastic Link Behavior (A) • Double-Acting Friction Pendulum Isolators (A) Code: *************************************** Mirror:
Code: *************************************** Code: *************************************** Code: *************************************** RE: SAP2000 V15.0.1 - cx_oem - 08-19-2011 OTHER LINKS Code: *************************************** Code: *************************************** RE: SAP2000 V15.0.1 - kowheng - 08-19-2011 Mirror Links: RAR 3@200+65 MB Enterupload Code: *************************************** Code: *************************************** Code: *************************************** Code: *************************************** Code: *************************************** Code: *************************************** RE: SAP2000 V15.0.1 - ascetic19 - 08-20-2011 Size: 635.92 MB
mirror links Code: *************************************** unique links for direct from multiupload, megaupload etc. RE: SAP2000 V15.0.1 - joker™ - 08-20-2011 HotFile Mirror in one link Code: *************************************** RE: SAP2000 V15.0.1 - joker - 09-17-2011 Full DVD 1.6 GB Code: *************************************** RE: SAP2000 V15.0.1 - dell1564 - 09-26-2011 OTHER LINKS - Sap 2000 v15.01StandAlone Code: *************************************** RE: CSI SAP2000 v15 - David90 - 10-14-2011 CSI SAP2000 V15.0.0 FULL DVD MIRROR LINKS Size: 1.63 GB
SAP2000 15 Enhancements - New graphical user interface with tabbed windows. - New DirectX graphics. - Display and output of frame stresses. - Load optimization feature to determine the optimal loading scale factors to achieve goals and limits on displacement and force response throughout the structure. - Built-in European concrete and steel material properties. - Canadian NBCC loading for wind, seismic, and response-spectrum. - American ASCE-7 loading for wind, seismic, and response-spectrum. - Italian NTC 2008 response-spectrum functions with geographic database. - Indian steel frame design code IS 800 2008. - New Zealand steel frame design code NZS 3404-1997. - Canadian steel frame design code CSA S16-2009. - Updated Hong Kong concrete frame design code to include Supplement 1. - Australian concrete frame design code AS3600-2009. - Enhanced Eurocode 3-2005 steel frame design, including design for Class 4 sections. - National annexes for Eurocode 2-2004 concrete frame design for Singapore, Germany, and Portugal. - National annexes for Eurocode 3-2005 steel frame design for Singapore, Germany, and Portugal. - Hybrid steel frame section property. - Simple arc for tendon profile definition. - Updated API functionality. - Import of StruCAD*3D design parameters and wave acceleration loading. - Note that the Bridge module has been moved to the CSiBridge product with expanded features and capabilities. Basic moving-load analysis has been retained for non-bridge applications. - Other minor enhancements. Code: *************************************** |
