EN 13286-2:2005 and BS EN 13286-42:2003 - Printable Version +- Civil Engineering Association (https://forum.civilea.com) +-- Forum: eBooks (https://forum.civilea.com/forum-63.html) +--- Forum: Codes, Manual & Handbook (https://forum.civilea.com/forum-16.html) +---- Forum: British Standards (BS) (https://forum.civilea.com/forum-120.html) +---- Thread: EN 13286-2:2005 and BS EN 13286-42:2003 (/thread-23473.html) |
EN 13286-2:2005 and BS EN 13286-42:2003 - Grunf - 03-16-2011 European standard EN 13286-2:2005
Unbound and hydraulically bound mixtures. Test methods for the determination of the laboratory reference density and water content. Proctor compaction, European committee for standardization. Code: *************************************** BS EN 13286-42:2003 Unbound and hydraulically bound mixtures. Test method for the determination of the indirect tensile strength of hydraulically bound mixtures Status: Current Publication Date: 18 March 2003 Cross References: prEN 13286-50, prEN 13286-51, prEN 13286-52, prEN 13286-53 International Relationships: EN 13286-42:2003 Identical Supersedes Draft: 00/101853 DC Descriptors: Roads, Construction materials, Mixtures, Tensile strength, Strength of materials, Tensile testing, Mechanical testing ICS: 93.080.20 Committee: B/510/4 ISBN: 0580414159 Publisher: BSI Format: A4 Pages: 12 Code: *************************************** EN 13286-2:2004 - ir_71 - 07-07-2011 EN 13286-2 Unbound and hydraulically bound mixtures - Part 2: Test methods for the determination of the laboratory reference density and water content - Proctor compaction Author: CEN/TC 227 | Size: 0.32 MB | Format: PDF | Publisher: CEN | Year: 2004 | pages: 29
This document specifies test methods for the determination of the relationship between the water content and the dry density of hydraulically bound or unbound mixtures after compaction under specified test conditions using Proctor compaction. It allows an estimate of the mixture density that can be achieved on construction sites and provides a reference parameter for assessing the density of the compacted layer of the mixture. This document applies only to unbound and hydraulically bound mixtures of aggregates used in road construction and civil engineering work. It is not applicable to soils for earthworks. The results of this test method can be used as a basis for comparing mixtures before use in road construction. The test results also allow a conclusion to be drawn as to the water content at which mixtures can be satisfactorily compacted in order to achieve a given dry density. This test is suitable for mixtures with different values of upper sieve (D) size up to 63 mm and an oversize up to 25 % by mass.
Code: *************************************** EN 13286-42 Unbound and hydraulically bound mixtures - Part 42: Test method for the determination of the indirect tensile strength of hydraulically bound mixtures Author: CEN/TC 227 | Size: 0.05 MB | Format: PDF | Publisher: CEN | Year: 2003 | pages: 8
This European Standard specifies a test method for the determination of the indirect tensile strength of cylindrical specimens of hydraulically bound mixtures. This European Standard applies to specimens manufactured in the laboratory or prepared from cores.
Code: *************************************** RE: EN 13286-2:2005 and BS EN 13286-42:2003 - ssobhan - 09-11-2014 Mirrors; EN 13286-2_e_stf Code: *************************************** Code: *************************************** |
