03-26-2010, 04:34 PM
(This post was last modified: 03-27-2010, 07:35 AM by BennyP. Edit Reason: )
Autodesk AutoCAD LT 2011 x86 Multilingual
AutoCAD LT is designed for the design and detailing of drawings, with product development focused on improving the productivity of professionals. Complete set of 2D instructions, you can create drawings, modify them and produce working documentation for projects. The program works with files in the format DWG; thanks to this project files can be easily transferred to other specialists. In addition, you can customize the user interface to fit your needs.
Downloaded from Rapidshare and installed. This is a deployment version (exe. file). Need a lot of time to open on HD before install but burned DVD from the image don't work so must install from exe.
![[Image: screen.png]](http://forum.civilea.com/postgen/screen.png)
![[Image: 63463443603171718264.jpg]](http://pic.civilea.com/images/63463443603171718264.jpg)
![[Image: password.png]](http://forum.civilea.com/postgen/password.png)
