Bentley RAM Structural System 14.00.04.01
The RAM Structural System is powerful and versatile special purpose
software for the analysis and design of building structures. It is useful in the
design and analysis of commercial, institutional and industrial buildings.
The RAM Structural System automates the process of calculating tributary
loads, live load reduction, gravity member selection, frame analysis, drift
control, frame member and joint code checking, special seismic provisions
member and joint checking and foundation design.
The RAM Structural System is composed of a number of special purpose
modules, each of which is invoked from the RAM Manager. The RAM
Modeler provides for the creation of a model of the entire structure,
including roof and floor loads; beam, column, brace and wall geometry and
locations; and slab properties, openings and edges. Powerful, yet easy to
use graphical model generation features are provided which allow complex
floor and building systems to be modeled in a short time. The result is a
comprehensive database of building data which can be accessed by the
analysis and design modules, providing a completely integrated solution.
[Image: 28751861194394966645.gif]
The previous Struceng medicine works so search or ask struceng to upload again.
[-] The following 31 users say Thank You to BennyP for this post:
  • StaadEng, rendel_©, sonidero, haze, hzaheer, goober, Dell_Brett, aslam, sasan51, oreslaw, chenamoy, narendra, erimajus, tolesa54, Finna, rajeev, đầuto, ruaumoko, teastf, kowheng, tangosuite, chinh, faxel, kashero, ocjocj, kerenski_t, selm27, eliseo.as, adams, ting tsai huang, subin91
This is the most recent one hoping that helps:
Password:
_________________________________________________________________
Post edited. Pass added.
Bentley RAM Structural System (SELECT Series 4) 14.04.03.00 BennyP 6 7,445 04-29-2012, 10:11 PM
Last Post: joker™
BENTLEY STRUCTURAL V8i XM + BENTLEY ARCHITECTURE V8i XM mohcivil 0 2,540 02-18-2009, 08:09 PM
Last Post: mohcivil
