Risa Tower
any one can help.
after i run Risa Tower model i got error message when i try to generate reports in Microsoft Rich Text Format (RTF) it says the file with rtf extension could not be found
Try to change your regional settings/Number formats and then check your reports...
Best Regards,
Ahmet Erdem Duran
[-] The following 1 user says Thank You to AhmetErdem for this post:
  • delwill_2
Hi Ahmet, can you elaborate, I am not clear!
Del
(06-01-2010, 04:18 PM)delwill_2 Wrote: Hi Ahmet, can you elaborate, I am not clear!
Del
Hi Del,
If you have changed your computer,s Number format settings, it may cause some problems during the calculation and taking reports. I had some problems the same problems and after I reset my regional settins and It is ok.
Please follow the instructions shown below,
Start/Control Panel/Clock, Language, and Region/Region and Language/Change the date, time or number format/Additional settings/Reset.
How can it be drawn different Plan Bracing templates in RISA TOWER. AhmetErdem 0 1,714 07-30-2010, 02:57 PM
Last Post: AhmetErdem
