Base Plate with Rib plates design
Hi there fellow civil engineers. I would like to ask if you have some example for the design of base plates with rib plates. As of now I only have AIJ coefficients and some Timoshenko et al coefficients to design and check for the moment capacity of base plates. As of now I'm comparing the AIJ results to Timoshenko coeff results, but not all sides were available in Timoshenko, for example a portion with 3 sides fixed and 1 side free. Can you please share your own design procedure or if you are familiar about this can you please share your knowledge. Thanks!
[-] The following 1 user says Thank You to joradu for this post:
  • fwrjel311
Hi
in "AISC Design Guide 01 - Base Plate And Anchor Rod Design" is some good information about this topic
if you dont have it tell me by email to forward this PDF Guide file
this is good refrence
[-] The following 1 user says Thank You to mojtaba808 for this post:
  • joradu
check this
Beam-Column Base Plate Design
[-] The following 7 users say Thank You to sia1 for this post:
  • Dell_Brett, kowheng, Nilupa, lucky_b2me, wannaspk, jcoronellr, joradu
You may also use this simple spread sheet based on US code. The steel sections are US.
[-] The following 3 users say Thank You to wannaspk for this post:
  • pedroxl66, joradu, nickycruz
Pedestal, Base Plate and Anchor Bolt Design usman 0 4,910 12-01-2010, 11:42 PM
Last Post: usman
