STAAD.foundation V8i Release 5.0 Problem
i am having problems when i use the foundation toolkit.
it stops working. when i use the the general foundation everything is fine
i'm using xp sp3 and foundation 5
does anyone have the same problem ?
fixed, i re install program and medicine and wallaaa working
staad foundation 5.0 cannot analyze mat foundation because it will appear that license is expired
Can someone probably fix the medicine for this so that mat design will also work.
I had the same problem with the mat analysis, and I copied the IEGLiclib.dll file and pasted it into every folder inside of C:/staad.foundation 5, but probably its neccesary only in the folder Analysis or SProStaad.
Now everything works fine.
Can you post the IEGLiclib.dll that you used. Thanks in advance
Staad pro installation problem jigarcivil 4 2,861 10-11-2010, 07:17 PM
Last Post: ssi3k
