Easy CurveFit v4.0
Easy CurveFit v4.0
Easy CurveFit is a small application designed to allow you to easily plot a curve through any graph of results that you enter into the application.
When first opened, Easy CurveFit is a complete mystery. It's totally unclear what to do with it, as the interface is very abstract and unresponsive. Hovering doesn't give you any clues, and right clicking elicits no response. There is a manual included however, but unfortunately it's very brief and written in bad English that makes little sense!
Basically, to use Easy CurveFit, you have to create a .txt file with your numerical results entered. Then this can be opened, and the points plotted on a graph. You can then, by clicking the various algebraic buttons, create a curve that bets fits your results.
This curve image can be saved, and you can zoom in and out too. While that curve drawing works fine, it's difficult to see what's special about it. While the curve results are good, it's a very clunky interface to use - it would be much improved if you could manually enter results to be plotted, instead of doing so in a text editor first. There are also a distinct lack of options.
If you want to create best fit curves, and save or print your results, Easy CurveFit does the job, but it's not easy to use or well explained at all.
Languages:
English
Limitations:
10 uses
OS requirements for Easy CurveFit:
* OS: Win2000/XP/2003/Vista
[Image: 26105038436497844700.jpg]
I CANNOT CHANGE THE DIRECTION OF THE WIND, BUT I CAN ADJUST MY SAILS TO ALWAYS REACH MY DESTINATION - JIMMY DEAN
[-] The following 12 users say Thank You to Gabemzaman for this post:
  • kowheng, SUSheikh, lucky_b2me, iceman84, osin, ivanveliki, ska51, weather, sudershan, yamacdere, Arigato, sodapas
[Image: comments.png]
"Downstream is Weaker"
[-] The following 11 users say Thank You to ska51 for this post:
  • Dell_Brett, jonny78, blaze, lisine, Arigato, 3fan, ssobhan, usman, fuchiguis, isurya, geomahesh
Portable of Easy CurveFit
“His blue eyes are often bloodshot, and their expression indicates that there is a helpless, baffled soul squirming around inside this doughty fortress.” Prue by Alice Munro, ©1982.
[-] The following 6 users say Thank You to ssobhan for this post:
  • Dell_Brett, ska51, usman, malc, utan, Batman07
